Water is coming through the front ceiling console where the map lights are. Any ideas?
I had the same probmlem its coming from one of 3 lights is the center quick fix was to use clear silicon from wal mart .. also it can leak from the moulding near the corners of the windsheald but rare...
I had the same problem with my roof lights leakin water. you have to remove the lights with a screw driver and apply silicone to the rubber gaskets on all the lights just to be safe.Hope that helps.
I had the same problem and fixed it with silicone. Do the same to the three lights in the back on the roof.
If no sunroof, I'd say concentrate on roof rack mounting bolts or screws. Only while driving in rain, or even sitting still in rain?
This Hummer has a sunroof. When I was checking the roof running lights, they all seems loose, but I can't figure out how to remove the running lights to check the seals. Leaks while dirving ans sitting
