I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck.
<!-- from fixya rte -->
If you don't leave the door open when not in use and not wipe the door dry and the door gasket dry, mold will build up as there is no air to let the moisture escape into. Makes sense, manufactures do no not say this in their manuals, I think they should !
Maytag's solution was to run an empty load using hot water and a cup of bleach instead of soap. According to them you are supposed to do this quite often. If the rubber ring that seals the door gets mold on it you are supposed to use a water/bleach solution and wipe it down with a rag.
YES GETTING RID IF THE MOLD WILL HELP YOUR PROBLEMS BUT YOU WILL HAVE TO GET RID OF ALL THE MOLD AND ALSO CONSULT YOUR DOCTOR FOR A CHECK UP SOME MOLD SPORES CAN CAUSE SERIOUS DAMAGE
Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversable, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everthing. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. We used strong vice grips and much struggling and sweat, and #@*&%!&@ and finally got it on without damage to the new gasket. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
