Question about HP DeskJet F4280 All In One Printer InkJet
F4280 not able to set the size of paper scan!#@$
The HP F4280 software did not let you select! Everything base on default!
Everytime I scan a A4 size, it will show memory low. Whereby i am using core 2 due 2.13GHz, 2GB ram, 8600GT, vista.
Posted by hc_chua on
Anonymous
    Problem Solver:
  • 5 Answers
1. All you need is Uninstall the the printer from your control panel.
2. go to my computer and open your Hard drive (C:)
3. Go to the programs folder and open it.
4. delete the HP F4280 folder.
5. reinstall the printer.
Make sure that your printed is not connected to your PC during software installation until you are being told to do so.
Posted on Sep 11, 2009
Anonymous
My hpdeskjet F4288 dos not print black print show error incompatible cartridge
Posted on Sep 14, 2009
How to change letter copy size to a4?
If the paper is size is set wrongly, then you need to change the default paper size of your printer.
Click Start and go to settings.
Click printers. Right-click your printer model and select Properties. Click the paper tab.
Choose the size of paper that you require to use in the paper Size-box.
Make sure to load the correct paper for the printer mentioned in the paper tab.
Click OK and then close the Printers folder. Most of the HP Laserjet printers automatically detect the paper sizes loaded in the paper trays thanks to the sensors present in the paper width guides.
For a better method, go to the Control Panel on your computer and select Devices and Printers.
Right-click on your printer model from the list and select Printer Properties.
Change the paper size from A1 to A4. Set manual feed to A4 instead of Letter. Call Our Toll-Free 1-866-293-9220
Sep 18, 2018 | HP Office Equipment & Supplies
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Unable to scan a4 size paper
Check the default paper type for your scaner, change the paper size to A4 and try the can again
Dec 29, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
How do I change the default paper size from Letter to A4 in my HP Officejet Pro 8500 Wireless?
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP Printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | Office Equipment & Supplies
Whenever i change paper size from A4 to letter,
Go to [Start]
right-click on the HP printer entry
Select [properties]
[Advanced}
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
My HP F4280 doesn't scan entire page. How do I adjust it?
in your scanning software choose the right paper size and click scan.
Aug 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
HP6110 default paper size for copying
Yes, manually set your paper size using A4 or begin with A4 and leave it on auto (default) it will try and match it.
Instructions...
  • Press Menu
  • Option 1
  • Option 2
  • Select copy Setup
  • Select paper size
  • Hit the black triangle until the size you want displays
  • Then hit enter.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printing from wrong tray
Go to printers and faxes and right click and properties on your printer!! Then select Advance, then Printing defaults!! In there select paper size A4 format. And in Word go to File, Page setup and select page size A4!
Jan 24, 2008 | Office Equipment & Supplies
HP DeskJet F4280 All In One Printer InkJet Logo
185 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
