Question about Hitachi Televison & Video
I can't get my Hitachi 51f510 to reconnect to my Wi-Fi signal.
Just got this tv. I was trying to learn the remote functions and hit the wrong button I guess. All I have is snow on the screen and I can't reconnect to my wifi. go into input or source and highlight wifi
Posted by Theresa Poitras on
5 Related Answers
sandrew
andrew pester
  • 2961 Answers
SOURCE: No Signal
You will have changed the video/audio input, on your tv, it should be an input button on remote. The signal will either be on AV1, AV2, AV3 Component or HDMI.
Posted on Jan 24, 2007
Anonymous
SOURCE: Hitachi 51F510 screen wont turn on
replaced new convergence board hitachi 51f500, magic focus wont work so i can align colors,any suggestions
Posted on Dec 12, 2007
Silverblade
Aris C.
  • 173 Answers
SOURCE: Wi-Fi problem Toshiba A15-S157 laptop
If your laptop has a di-fi switch/button chances are you have one integrated on the main board of the laptop, check if the wi-fi adapter is installed properly by going to the Device Manager and check Network Adapters normally a wi-fi adapter will show up if not check if you have any devices listed under network devices(Network Controller, Ethernet Controller). Now if the wi-fi card is installed and the status on the Device Manager say's that it's working properly, you may now check your laptop for a 3rd pary wi-fi utility/application that manages your connection look for it on the System Tray on the lower right hand side near the clock or go to all programs and look for any WLAN utility, when you open the utility make sure the wi-fi radio is turned on or enabled.
Posted on Nov 05, 2008
Anonymous
  • 108 Answers
SOURCE: compaq c700 wi fi not working
Have you checked that the wireless network connection is not disabled in "control panel" "network connections". Also check Device Manager and make sure that the wireless device is listed under network adapters. Have you turned off the wireless device in the bios? If you need help with any of these let me know. I will also need to know which operating system you are using i.e. XP or Vista
Posted on Jun 09, 2009
Gort007
Just Gort
  • 1187 Answers
SOURCE: My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Posted on Oct 06, 2009
My old zte after I factory reset it it wont let me connect to a network
Here are 4 solutions for your reference.
1. Restart your ZTE and reconnect Wi-fi on it
2. Forget the Wi-fi you are connecting
It is probable that there are something wrong with the Wi-fi which your phone is currently connected to. For example, the password of the network is changed but you are still using the old one. In this case, you can wipe the Wi-fi on your phone and then re-add it manually. The details are as below:
3. Check out the router
As we mentioned above, router plays an important role in mobile phone Wi-fi connection. So it is essential for you to check the running status of the router. If you have no idea whether it works well or not, you can try to restart the router or even reset your router to fix the issue. After that, you can reconnect your device to Wi-fi to see you can hook up to Wi-fi this time.
4. Reset Network Settings on ZTE
Another possibility of Wi-fi connection failure might be Wi-fi caches. It seems that Wi-fi does not create any caches on the device but this thought is wrong. Wi-fi networks produce cached data as well, especially when you connect a bunch of wireless networks on your phone. Hence, you are advised to reset the network settings on your phone to clear these caches.
Aug 07, 2018 | ZTE Cell Phones
Setting up internet on akai smart tv
How to connect
  1. hit the Menu button on your TV remote.
  2. choose the Network Settings option then Set up a wireless connection.
  3. select the wireless network name for your home Wi-Fi.
  4. type your Wi-Fi password using your remote's button.
Feb 11, 2018 | Televison & Video
How to set up if tv number for magnavon is not listed none of the numbers work
Depending on the type of remote you are trying to pair your tv to, you can try using a learning function or an update function. With a learning function, you can train the universal remote to control any button of any device that accepts IR signals and you physically have the remote.
If you are trying to pair a Magnivision television, try using the Philips codes.
If your universal remote does not have a learning function, or the ability to update, try getting one that does. DISH Network has remotes style 20, 21, 31, and 40 for ViP and Hopper equipment that have learning functions, or you can try the Logitech Harmony (below).
Mar 02, 2015 | Televison & Video
My Wi-Fi on Lenova Think Pad T60 is not working. I tried to update the drivers. Still not working.
What is it doing? Still not working could mean a lot of things!!! Is the computer connected to the wireless network? You've got to connect to the network before you can do anything. And most times the problem with connecting to the network is people key the network key or password wrong so the wireless just keeps on polling trying to connect.
Do you have the wireless turned on on the notepad? Sometimes there might be a wireless switch somewhere that you have to turn on. Also most times you can toggle the wireless On and Off by hitting the FN Function key and the corresponding F1 thru F12 key that toggles the wireless. Most times the correct F1 thru F12 key will have a wireless icon signal on it sorta like ))))) or it may show a tower with the signals. Once you find the correct F1 thru F12 key to press then Press and Hold the FN Function key then hit the correct F1 thru F12 key. If you look at your screen most times it will let you know if you've toggled the wireless by displaying Wireless On or Wireless Off.
Mar 29, 2012 | Computers & Internet
My tv is a hitachi hd ready flat screen plasma tv and i am using universal remote control The tv was working fine until i swtiched it off and hit one of the buttons on the remote - possibily the av...
What are u using for a signal source? Cable, Satellite, Over the air? My best guess is that you hit a wrong button such as the "source" button and the remote doesn't know what device you are wanting to opperate. Press volume up then down and see what light lights up?
If it is other than "TV" then you probably have the wrong device selected... Hope this helps... Sincerely HDTV GURU JAY
Mar 15, 2011 | Hitachi Televison & Video
Having a problem getting my samsung touch remote for 55c9000 tv, to watch tv on my remote it keeps saying that there are no tvs found? when i try and connect to my tv can someone help me solve this issue,...
I don't have a solution but just checking if you have set up your remote as an "extended distance wifi remote" as described in the manual. I have been trying to set mine up and when I follow the instructions to pair the remote to the TV I get a message on the TV screen to "Allow" or "Deny" access. Problem is I do not know how to select "Allow" as the remote is unavailable to use as it is part of the pairing process. I can highlight "Allow" by using the volume button on the TV but don't know what button to press to enter my selection.
Nov 22, 2010 | Samsung TV Remote Control
Hitachi 51F510 51 in. rear
try to enter your setup menu and auto programed the channels that you receive.
Apr 13, 2008 | Hitachi 51F510 51" Rear Projection...
Mbr3447 remote code for samtron vcr
Up untill a few years ago they used to make a lot of universals with a "learning" function, that you aim the thing at a certain device untill it figures out the right code for it. I read that the technology was bought since so you dont see those quite as often in the market. ok, if yours is a learning uni, here's a tutorial on how to fix it, in general terms since it varies between remotes: If you cannot get the instructions - most "universal" remotes have a "code search" feature. Usually this involves hitting the "program", "select" or "function" button, then pressing the device button ("TV", "VCR", "AUX") then repeatedly pressing the "power" or "channel up" button until the set responds. The remote will cycle through each of the codes (01, 02, 03, 04) sending the "power" command for each. When you hit the right code - the set responds. When the set responds, stop and then press the "program" or "function" button to enter it (which button varies between mfgrs). If you count the number of presses - that should be the code (12 presses is "12" or "012" - or it could be 11 if the codes start at 00). If you do not have a "program" button (it might be hidden), then you may have to instead hold the function (TV, VCR, Cable) button down for a few seconds (until the light blinks). The usual manual sequence is: 0 1 2 It might also be: 0 1 2 If no program button: 0 1 2 Some remotes use a two digit code, some use three. It'll take quite a bit of trial and error without the manual. you can try getting the codes from the manufacturer, go to their site and see if you can figure anything out there... good luck
Jan 19, 2006 | Zenith MBR3447 Remote Control
Televison & Video Logo
53 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
