Question about Refrigerators
Need a wiring diagram for a Mm14ge beverage air refrigerator.
I have a beverage air, and having problems wiring it back up.
Posted by Eddie Vargas on
5 Related Answers
Anonymous
  • 149 Answers
SOURCE: Beverage air ucr48 A problem
yes check the condenser coils if dirty, clean it
2nd you can be having a defective evaporator /condenser fan, make sure both fans are running.
3rd you can have a relay/start capacitor/overload problem i'd suspect this if compressor hums and trips.
Touch the discharge line of compressor it should be hot, if not, compressor ain't turning on.
If your coils iced up, suspect a faulty thermostat.
but before all of this i'd check for an iced coil.
Posted on Apr 22, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: My Beverage air model # mm14ge blows hot air.
Check the start relay and capacitor on the compressor.
Check the fan motor on the compressor.
Posted on Mar 19, 2009
Dennis Boxerman
  • 1303 Answers
SOURCE: need to see if evap fans r working
http://www.beverage-air.com/uploadedFiles/docs/CFG_CRG_KF_Series809-046A.pdf
this site has your manual and the manual has wiring diagram.
also has some common trouble shooting questions and answers.
Posted on Jul 11, 2010
Dennis Boxerman
  • 1303 Answers
SOURCE: Refrigerator not cooling
http://www.beverage-air.com/Main.aspx?pid=57&tab=58
go to this web site and find your exact manual. If you have any questions drop me a line
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: I need a wiring diagram for a Beverage Air MT10,
moz-screenshot-1.pngmoz-screenshot-2.pngI followed the brown wire back to the common terminal on the condenser fan switch.
Posted on Jan 25, 2011
Adding freon to a commercial beverage air mm14ge cooler
If it needs gas it has a leak. These coolers generally don't come with gauge access ports and need to be silver brazed into place. These systems have a critical charge and will not operate right unless the exact ounces of refrigerant are in the system. The temperature controls measure coil temperature instead of cabinet temperature. The wrong charge makes them run and run and they cant control temperature. Hope this helped.
May 25, 2014 | Beverage-Air Refrigerators
I have a beverage air MM14GE cooler that hasnt been on for over a year when i plug it in it turns on but doesnt cool, what can be the problem?
Verify that the compressor is actually running. You should feel it vibrating. If the compressor runs with no cooling most likely the refrigerant level is low.
Oct 12, 2013 | Beverage-Air Refrigerators
My Beverage Air mm14ge wont cool. IT sounds like it's running, then after about 25 seconds it will click once, then once again a second or 2 later, and keep repeating that cycle. The fan is working. Is...
could be the start relay. could also be the compressor itself. need to either check continuity of compressor or use a compressor analyzer to see if shorted or open.
Apr 05, 2011 | Carrier Beverage-Air MM14 Commercial...
I need a wiring diagram for a Beverage Air MT10, where can I find it?
Jan 25, 2011 | Carrier Beverage-Air MT10-1 Commercial...
My Bev Air UR30G runs, but only warm air comes out...how can I fix?
make sure the compressor is running if not check the thermostat. or could have leak and lost coolant
Sep 27, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
Need to see if evap fans r working
Jul 06, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
My Beverage air model # mm14ge blows hot air. why, and what must i do to fix this please.....thank You
Mar 19, 2009 | Refrigerators
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
