My dr-s2.o reads no disk. There is a disk in the drawer
Posted by Michael D Laino on
  • Larry Ng
    Larry Ng Jun 17, 2019
    Hi Michael D Laino, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    moved youl.
Larry Ng
  • Audio Player... Master
  • 5,969 Answers
Google shows no response to dr-s2.o, wow !
so must we guess what it is , ?
a PC
Disk means DVD? what DVD is it , label words?
but 11 long years ago on this forum
its this Onkyo DR-S2.2 an Audio Players & Recorders
moving you out of comptures, now.
Posted on Jun 17, 2019
Whirlpool gold accubake system keeps displaying the message "Dr Lo". Every 60 seconds it will beep like 10 times and display the message then display "start?" Normal function dont work either I can push...
The Dr lo is for the warming draw. I assume you have a warming drawer. Page 17 of your manual describes how this function works. It also states on page 11 "The Off/Cancel pad stops any function except the WARMING DRAWER, Timer and Control Lock. If you have actually unplugged the stove and plugged it back in it should come on with a PF for power failure. You push the Off/Cancel pad to clear the PF and then you have to push start to do anything else. such as bake, etc. Have you pushed Drawer OFF? That should clear the dr lo message. If this message comes on as soon as you plug the stove in or just after you push the Off/Cancell pad or after you push start or bake try to push Drawer Off. If this does not work then it apppears you have a malfunctioning control panel.
Dec 18, 2013 | Kitchen Ranges
Samsung S2 1TB Hard Drive on my mac?
settings issue but more importantly the drive must be formatted for a mac. if that has not been done then that's what's on order.
back up data first though
Jun 18, 2012 | Samsung S2 - 1TB USB 2.0 Portable...
My Teac DR-H300 will not open the dvd drawer anymore. It looks like the magnet won't release on the drawer. Can anyone tip me what to do?
I solved this by holding the power button down for 5-10 seconds. After a reset the drawer opened as normal.
Dec 05, 2009 | Teac Reference DR-H300
DR-MV100B will not read disc
It could be a dirty laser. Try running one of those laser cleaning disks through it. That might help
Sep 22, 2009 | JVC DR-MV100B DVD Recorder/VCR
Computer hard drive
Try the disk in another computer.
If the other computer can read the disk, then the disk-reader in your computer is the problem.
Carefully insert a disk into your computer, noting which way the labelling on the disk is pointing.
Close the disk-drawer.
When the light goes out, open the drawer.
If the labelling is still pointing the same way,
the drive probably has _NOT_ spun the disk at all -- bad news.
Aug 13, 2009 | Computers & Internet
My disk tray won't read any disk just saying "open tray"
The switch that indicates the drawer position is stuck. Look for something in the path of the drawer. It should be totally clean.
Jun 29, 2009 | Microsoft Xbox 360 Console
Hp dvd/rw does not read discs
If the CD or DVD disks you inserted work in some other reader, then your reader is the problem -- even though it is properly connected to your computer, and Windows has the correct device-drivers, it is the "hardware" that is the problem.
When you insert a disk, rotate it to some position, i.e., top-lettering goes in first, and close the drawer. Do you hear the drive start to spin the disk? Open the drawer. Is the disk in the same (non-rotated) position? If so, then the motor that spins the disk is the problem. If the disk does spin, but nothing happens, then it is the "laser" part of the mechanics that is not working.
Replace it.
Apr 21, 2009 | LG GSA-H55N DVD-RAM Burner
"please wait"!
Is there not a drawer open/close button? Please wait usually indicated wrong type of disk and it is not being read or faulty laser. Switch it off and switch on then press the drawer release before it starts trying to read.
Jul 16, 2007 | JVC DR-DX5 DVD/HDD Recorder
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
