My tv and sound go off intermittently. I have checked for software upgrade, rebooted modem and unplugged tv. No solution with these measures
UA55JU6400KXXA
Posted by Herbert Schneider on
1 Related Answer
edward
  • 4 Answers
SOURCE: TV keeps asking for upgrades. After attempts to
Noise in 5 volt standby voltage may have already corrupted eeprom. Change the two 680uf/16 volt that filter the 5 volt stby and other bloated caps in power supply to see if tv is still salvagable.
Posted on May 13, 2015
You have to turn up the volume to 38+ in order to hear the TV, when you use to be able to hear it at 10, is there a control board that goes out and what Is the name of it?
Hi Geoff, I hope I can help you with this. If you are using an accessory device (DVD, DVR) check cables to see that they are secure and if device has audio out option that it is set correctly. Also check to see that Video and Audio cables are connected to matching inputs on your set.
If you are using DVI to HDMI you will need to use a separate digital audio cable. DVI cables do not carry audio signal. After attaching the audio cable if you still do not hear sound you may need to set Digital Audio In. To do so:
  1. Press Menu Button on remote.
  2. Press the cursor ring down to highlight SETUP.
  3. Press the cursor ring left to enter SETUP menu.
  4. Press the cursor ring down to highlight SOURCE.
  5. Press the cursor ring left to enter SOURCE menu.
  6. Press the cursor ring down to highlight DIGITAL AUDIO IN.
  7. Press the cursor ring down to select the source you want to associate Digital Audio with. HDMI 1 or HDMI 2 in this case. You might need a software update also.
    The latest software solves the issues below:
    1. TV (Plasma 42" and 50") will not turn ON/shut off itself and Red LED blinks 4- times. Recover if main switch on/off.
    2. 37" LCD full white screen appear when upgrade software.
    3. Some channels not available after turn ON.
    4. Delta volume changes, not remembered.
    5. Preferred channel changes, not remembered.
    6. Green or yellow static (sometime snowy) on HDMI picture.
    7. Picture and sound loss for 5 to 10 sec (green LED is still ON) and back to normal.
    8. Audio loss in all inputs and can be recovered when main switch ON and OFF.
    9. TV set turn ON by itself/ green LED light up and goes off when set is ON.
    10. Intermittent audio loss in NTSC RF channel.
    11. Crack sound with high input signal.
    12. Include the possibility to download the rating table (RRT5 capability) for digital programs.
    13. No video/ no picture with sound.
    14. Intermittent On-Screen Menu pop up by itself and can be removed by pressing the 'MENU' button.
    15. Channel information display too long.
    16. Improvement on scramble channel.
    How to check the current software version on my TV set?
    1. Press 'MENU' button on remote control to display the on-screen menu.
    2. Select TV MENU and press the cursor right.
    3. Select INSTALLATION and press the cursor right.
    4. Select SOFTWARE UPGRADE and press cursor right.
    5. Select CURRENT SOFTWARE INFO to display the current software version on your TV set.
    6. If the TV software version is lower than the version posted on the website means your TV set needs to be upgraded.
    7. Follow the instruction in the user manual or Firmware Upgrade Readme file on how to upgrade your software.
    Where can I find the latest software for my TV set?
    The Firmware Upgrade Software and Readme File documents can be found on the Philips support website. Refer to the SOFTWARE section.
Feb 04, 2016 | Televison & Video
No sound but picture on an RCA L32HD31R
Check all ur tv inputs cables connections from the back of the tv,for like AV components and or HDMI cables for losed connections or damages cables wires.If u have cable boxes,satalite boxes or telicom compannies boxes and it plug in 24/7?Yes?Unplugs,replugs those boxes and the tv also back about an hour later.For those boxes to reboot and upgraded it softwares and the tv to do a resetting itself back to the tv factory settings.Than goes into the tv menu,go to the tv Audio Settings,to do a whole resetting to all the audio settings back to the tv factory Audio Settings.These steps,will help for ur tv to have and to get it audio sound back again.
Nov 29, 2011 | Televison & Video
The tv speakers are turned off, i just want to know how do i turn them back on-I get no sound at all
Tries cable or satalite boxes and tv unplug,replug it back like about an hour later.For the tv resetting itself back to the factory setting and those pay boxes to reboot and upgrade the their softwares.Go into the tv menu goto Audio Setting,go down do a resetting to the audio setting back to the factory setting.By doing these steps,tv audio have a great chances of returning.
Aug 11, 2011 | Mitsubishi LT-52153 LCD TV
I have a Sony kd-28dx50u tv I can get a picture but no sound not sure what the problem is can you help thanks
Ur tv it is using a cable box or a satellite box?Yes,unplug,replug those boxes back like about an hour later to let those boxes to reboot and upgrade it softwares.Used ur tv remote.Go into the tv Menu go into the tv AUDIO Setting.If tv have resetting function,go down and used it for resetting back to the factory setting.By doing these steps,tv have a great chances of the audio returning.
May 07, 2011 | Sony Televison & Video
Internet gets connected slowly
Are few solutions for you:
# increase your cache size. It means the storage space where your visited web sites were saved.
# upgrade your modem.
# upgrade your Internet connection to a DSL, ADSL or satellite one.
# give a call to your Internet provider and do a modem and connection check. Maybe is not properly set up.
Mar 07, 2011 | Compaq Computers & Internet
The TV turns off and then on automatically
Tries to reset the tv back to the factory setting.Unplug the tv and the cable box too,replug it back about an hour later.Let the cable box reboot and upgrade it softwares.Go into the tv Menu.Go to the PICTURE setting.Go down to the reset,to reset the Tuner board,this will reset the the Tuner board,back to the factory setting.This should solved ur tv problems,not than,the Tuner board is defective,must be replaced.
Jun 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Intermittent DSL connection. Frequent need to reboot modem.
the modem is already old and obselete try to upgrade the modem. even though the lights on your modem works. try to call ATT because they can run a line test so they can determine if the connection is good or not
May 22, 2010 | Efficient Networks SpeedStream 5360...
I have to constantly reboot the router to get on the net ...what is causing this ?
I trhink you can try to upgrade the firmware of the router.
Firmware if the software of the router.
Did you try to connect it directly to the modem.
you can connect the computer directly to the modem and check whether it is working properly through the modem.
If you need to restart the modem constantly then it could be the issue with the ISP or the modem.
Click Here to know how to upgrade the firmware
Oct 25, 2009 | Arris WR850G Router (DHWR850G)
Intermittantly freezes on playback. Toshiba rs-tx20 dvr
shut down tv/dig box/dvd. unplug and then leave a little (cuppa time)
replug .then start up dig box then tv then dvd.sounds like in need of "reboot"
Sep 01, 2009 | Toshiba RS-TX20 DVD Recorder
I have a 6 month old LG LCD 42" flat panel tv that, from time to time when we turn it on, will have sound come on but no picture. The status light (on/off) turns green from red. Since this has...
A lot of these sets have a software upgrade that can take care of intermittent power on issues, check with the LG website and see if there is noe available for your model set, I have seen this solve these problems numerous times
Aug 19, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
