Question about Refrigerators
How do i removethe ice tray - Refrigerators
Posted by deborahpala on
JonSnell Electronic
    Top Expert:
  • Refrigerators Master
  • 31,513 Answers
Make and model of freezer may help you get an answer.
Posted on Jun 16, 2019
Whirlpool mod#ED5FHEXNB00 isn't making ice
Freezer temp has to be below 10 degrees for ice maker to work. Also check to see if water/ice is in the tray. If no ice in tray then the water solenoid valve is not feeding the unit. If ice in tray then the heater is not working to melt the ice a bit so it can be scooped out into the ice tray. And make sure the feeler arm is down into the ice tray bin - if not, ice maker is shut off.
Oct 05, 2015 | Whirlpool Refrigerators
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
How to fix LG icecube tray 3390JA115A
Hello there,
Fixing the ice cubes tray is quite simple, all you need to do is to hold the ice tray by the edge and gently slide it into the ice tray position. Pull out the drawer and place the ice tray into the freezer.
To make ice cubes, fill the ice tray to the water level and place it in the freezer.
Hope this helped. All the best Elect_Comp
Sep 22, 2011 | LG LRSC-26922 Side by Side Refrigerator
My ice tray moves fine and makes ice but for some reason it won't release the ice when it turns. Then the water tries to fill up over the full tray and makes a big mess. Any suggestions?
Either the icemaker support is broken, DA61-02205A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
First Choice Appliance
Jan 11, 2011 | Samsung RS2534 Side by Side Refrigerator
On my VISB542SS the ice maker , water leaks into the drawer when ice is being made, Ihave removed the unit to check for leaks bot find none.
The ice tray releases the ice because the mechanism twists the tray during the end of the cycle. Sediment builds up in the ice try over time and the smooth Teflon surface is no longer smooth, and the ice can get a "grip" on the tray. Then when the tray is twisted, a few cubes remain in the tray. When the measured amount of water then flows into the tray on the next cycle, it is too much. It freezes over the top of the tray, and the next time the tray is twisted, no ice falls out. When water is injected after this, it just runs off the top of the tray into the bin, freezing the ice in the bin. Replace the ice tray every 3-4 years with a new ice tray, and the problem disappears.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Oct 15, 2010 | Viking Refrigerators
Bosch Evolution B20CS50SNS about two years old. No ice is dispensed. Looked inside and tray is frozen over solid. Also looks like water has overflowed and frozen down in bin. Could not figure out how to...
I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
Dec 08, 2009 | Bosch Refrigerators
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
Amana side by side coil cleaning
removethe lower kickplate , under the doors, then with a refrigeration coil brush(avaailable at te hhradware stores) and a vaccumm you can clean the coils
Feb 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
