Question about Russell Hobbs Irons
Russell Hobbs Steamglide Pro iron. When turned on the power light, steam light steam level light and the filter light all flash and the iron does nothing
Posted by RRover on
5 Related Answers
Anonymous
  • 378 Answers
SOURCE: no steam
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Posted on Jan 04, 2009
Anonymous
SOURCE: Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Posted on Mar 24, 2009
Anonymous
  • 137 Answers
SOURCE: lost instructions on how to use self clean on my iron
It probably needs to be de-calicified, you can find the stuff to do it at most any hardware store.
Posted on Mar 28, 2009
Anonymous
  • 867 Answers
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Posted on Aug 10, 2009
Anonymous
SOURCE: russell hobbs steamglide 2400 iron water solenoid
So am I. Did you manage to source one?
Posted on Feb 03, 2011
Instrution manual for russell hobbs 17880
i need an instruction booklet for a russell hobbs steamglide iron model number 17880 any helpers please .
Jan 20, 2012 | Russell Hobbs Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
Russell hobbs steamglide 2400 iron water solenoid
Jan 26, 2010 | Irons
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
Aug 10, 2009 | Irons
Lost instructions on how to use self clean on my iron
Mar 28, 2009 | Irons
Irons Logo
212 people viewed this question
Top Russell Hobbs Irons Experts
NOEL
NOEL
Harrie
john h
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
