Question about Refrigerators
Fujitsu AOU24CL1: problem- red&green lights blinking twice, then only red light 5 times, outside fan stops, indoor- blowing hot air. Please help, freon checked and it's full, no leak, filter-cleaned.
Please ASAP, otherwise my refrigerator inside of garage will die, too hot. Thanks a lot guys.
Posted by Aleksandr Gazarov on
Steve F
  • 1,360 Answers
It appears that it is a "25" error. This is a "PFC" error. One of the circuit boards has failed. You could try a full power reset by turning the machine off at the power supply for at least 30 minutes and then trying again.
Posted on Jun 16, 2019
5 Related Answers
heavymetal77
Pete MacSparran
  • 721 Answers
SOURCE: ac not working, blows hot air only. Recharged
Check the evaporator coil by sniffing the vents,floor is best, with your tester.
Posted on Jul 16, 2009
JAY
  • 251 Answers
SOURCE: MY frigidaire Air Conditioner model
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
bugoy31
bonifacio gomez
  • 1238 Answers
SOURCE: MY FUJITSU A/C indoor model# ASU36CLX
Good day!!!!
the manual said that error code is cause of discharged thermistor..
-The detection value of the discharge thermistor is either open or shorted > Compressor, outdoor fan: OFF (automatically
releases when the value is returned to normal)
-Check the thermistor resistance values (refer to thermistor value chart)
-controller pcb defective...
Or try to click this link to see the diagnosis:
http://www.e-comfortusa.com/PDF_files/Fujitsu/12RLQ/Fujitsu_12RLQ_Halcyon_System_2008_Troubleshooting_Guide.pdf
Hope it helps..
Thanks for using fixya..
Posted on Aug 12, 2011
Jon Shapiro
  • 3 Answers
SOURCE: Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Posted on Oct 28, 2011
SOURCE: fujitsu asya09lcc wallmount split lights flashing indoors
just happen to me, call the service guy........... he told me to cut power for 30 minutes cause it erase memory inside machine. I did and its working........ So happy
Posted on Jan 05, 2012
Very hot between doors
Warm in that area is normal because heated Freon travels around the door frame on most refrigerators because it prevents sweating between the cold inside of refrigerator and the cold air inside of freezer The problem of getting hot may indicate a defective condenser fan or the air below refrigerator is obstructed by dust. Check those two things and if you have any question I will be here to answer them for you. If helpful please rate this solution, Thanks Sea Breeze
Feb 29, 2012 | Admiral 26 cu. ft. Side-By-Side...
I have a chamberlain motor lift model number ml700 gb...someone installed it incorrectly and garage door is actually not connected to the motor itself, is there a chain or something that connects the two...
These have to be installed in a professional manner. One very important part is the installation of the safety release catch, otherwise if the motor fails, your garage door will be locked from the inside.
Here are the installation instructions.
https://www.byko.is/media/byko/fagsolusvid/ML700-leidbeiningar.pdf
Sep 12, 2017 | Garden
Refrigerator/freezer in garage not freezing
Most refrigerator Manufactures have tested these machines in hot and cold weather and weather will effect operation and electricity consuption.
As far as cold weather goes It would run much better in cold weather than hot. As far as it being in the garage : It will wear on it faster. The humidity is not good on them and they get more dirt through the system and will need its normal mantenance more often. not to mention bugs and rodents like to find a warm place to hid with fee dinking water and a refrigerator provides that for them.
Jan 09, 2010 | Whirlpool ED5HHEXT Side by Side...
Refrigerator died, applicance guy couldn't find problem
defrost heater tube is bad - or defrost relay - or defrost timer.
May 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator
hi thanks for the question it looks like you have a drain problem the drain tube goes to the back of the fridge by the compressor it is clogged up clean tube thanks te appliance doc
Sep 26, 2008 | Freezers
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Honeybee model #Green733
Check the CMOS battery, as this has been my experience regarding this issue. Most likely, especially if the machine sat for some time, the battery died, and simply needs to be replaced. Very low cost ($4-$5), simply corrected issue, if that is the problem. Very possibly the battery had just a bit of "life" left in it, and once it was done, it was done.
If this doesn't work for you, or you need further help, please post back. Otherwise, thanks for rating FixYa!
May 10, 2008 | Computers & Internet
Ipod charges,heats up on bottom right.Battery dies fast.Replaced battery,still same problem
It sounds like the battery has shorted out. Ship this guy out and have his battery replaced ASAP! This is a giveaway with the heat. Please note that it is "problem solved!"
Jul 27, 2007 | Apple iPod MA446LL/A MP3 Player
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
