Televison & Video Logo
Question about Sansui Televison & Video
I need a code for a sansui TV. To be able to turn it on
Posted by Cathy HOLMES on
Franco Dosil
    Top Expert:
  • Sansui Master
  • 10,542 Answers
Hello Cathy, comment on the model of your TV Sansui and the brand and model of the remote control, for which you are needing the code, to try to find the best possible solution
I await your comment
Greetings Franco Dosil
Hola Cathy, comenta el modelo de tu TV Sansui y la marca y modelo del control remoto, por la cual estas necesitando el codigo, para tratar de encontrar la mejor solucion posible
Espero tu comentario
Saludos Franco Dosil
Posted on Jun 16, 2019
Patrick McGill
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Here is what I found online for universal remotes:
Sansui television remote code 834
Sansui television remote code 0310
Sansui television remote code 0394
Sansui television remote code 20695
5 Related Answers
Anonymous
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Posted on Jun 21, 2008
Anonymous
  • 5 Answers
SOURCE: I need codes for a sansui tv
Sansui 0463
Posted on Mar 20, 2009
Anonymous
  • 9 Answers
SOURCE: need to find tv code for sansui
http://kbase.x10.com/wiki/Universal_Remote_Code_List
try this
Posted on Apr 11, 2009
Anonymous
  • 159 Answers
SOURCE: need code for Sansui TV
sansui: 1929, 1911, 1904
or use the general programming tool:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Posted on Apr 14, 2009
gopakumarg43
  • 76851 Answers
SOURCE: need code for sansui tv
Hello
Check these setup codes.
096 145
http://www.dataentryjobs.us/67948.html
http://www.sfippa.com/11593028/real
http://www.oneforall.com/pdf/URC-7960_English_Manual.pdf
Posted on Feb 29, 2012
Service code for 32inch sansui led tv sled hdr
Sansui model - LCD TV s 3281Yw-M I need sarvice mode code plz tell
2answers
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
1helpful
2answers
Trying to program my sansui tv with the cablevision remote control. unable to find codes
You have to do the universal way which involves:
1) turn on tv and dvr
2) press tv button + select, hold till the io button stays lit (5seconds)
3) once io button is lit, press up and down channel buttons and flip through them until the tv turns off.
4) press mute, this should turn the tv on.
5) press tv button to save the settings (turn off tv)
2answers
Program my TV
Try entering code: 0463.  I have the 27" Sansui, but the code should work for all Sansui TVs.
1helpful
Want user manual
here is a link to your manual
http://support.rca.com/doc/Device_Documents/manuals/RCR311B_manual.pdf
the codes for a sansui tv are:
Code For Model RCR311B
Code 1191 for Sansui TV Code 1247 for Sansui TV
instructions:
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box).
2.Press and hold the TV key. The illuminated ON•OFF key turns on andremains on. If you release the component key at any time during theDirect Code Entry procedure, the illuminated ON•OFF key blinks fourtimes, and the process is exited.
3. While holding down the TV key,use the number keys (0-9) on the keypad to enter the first code above.While you are pressing the numbers, the illuminated ON•OFF key turnsoff.
4. After the fourth number is entered, the illuminated ON•OFFkey turns on. At this time, release the TV key. If the illuminatedON•OFF key turns off, you have entered a valid code and have followedthe correct procedure for Direct Code Entry. If you enter a code numberthat is not in the Code Lists or you do not follow all of the steps forDirect Code Entry, the illuminated ON•OFF key blinks four times whenthe TV key is released. This is an indication that a programming errorhas occurred. In that case, repeat the Direct Code Entry process fromstep 2 and try the next code listed.
5. To confirm that thecomponent key is programmed with the correct code for maximumfunctionality, test the component. Attempt to control a variety of thecomponent’s functions with the remote. If some of the features of yourcomponents do not work, try programming the remote with a differentcode in the list until you find the code that allows the remote tocontrol the majority of your component’s functions. Different codes canprovide different levels of functionality.
7. Remember to write the code down for future reference
2helpful
2answers
Help for Sansui URC-3605 one for all remote control codes. Need T.V code.
try these codes 0000, 1479, 0479 - from our control booklet
Need to find a code to work the tv/vcr combo from a comcast digital remote
Try the codes for Orion, Emerson and RCA as well as Sansui. Good Luck!
2answers
Universal remote wont work with this TV
Questions: Who is "Sansui", the digital box ? or the TV? Is the "digital box=remote control"? turn on what you want to control.
Face the RC face down or away from TV,or whatever you want to control. Usually:: push & hold TV & SEARCH button until light blinks, two, three times? FACE THE TV and put the code for the [TV=Sansui ?] You said #189 try 0189 [zero,one,eight,nine]
2nd) TV power ON!,....HOLD down (and if you have a SEARCH) button and the tv power button on RC, two or three blinks, push up arrow once, press power button for TV on RC, nothing!, continue...up arrow, power button. when the TV turns off, you have found the code,. YOU MAY HAVE TO DO THIS 50-150 TIMES because the RC is looking through EVERY code!
Sometimes
62helpful
10answers
CODE RETRIVAL FOR A SANSUI TV MODEL
I lost the remote to my Sansui TV and can't remember the model number. can I get a remote to replace it?, the tv was bought in 2004
Top Sansui Televison & Video Experts
Paul Bade
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
