Question about Ricoh Office Equipment & Supplies
I have photocopy machine model is Ricoh Aficio mp2550 is not working .when start the machine panel stuck and hang the machine no ready
Posted by ijaz Shah on
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Ricoh Aficio 1018 photocopier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Posted on Nov 30, 2007
Anonymous
  • 78 Answers
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Posted on Mar 19, 2008
Anonymous
  • 87 Answers
SOURCE: ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
Anonymous
  • 58 Answers
SOURCE: Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Posted on Feb 27, 2010
Pasword on photocopy
Read the manual.
Get online and got to www.google.com In the google search box type: "Ricoh Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manual.
May 30, 2012 | Ricoh Aficio 2027 All-In-One Laser Printer
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
How do i restrict use to an aficio MP2550 photocopier
Hello sir; You may go to user tool key open up copy setting,looking for user code setting.
Jun 03, 2009 | Ricoh Office Equipment & Supplies
ERROR of My Aficio MP1500 Photocopier
Are you sure about the model number? I believe you may mean MP2500? Regardless, sounds like an NVRam Problem. This unit is what controls the electronic counter, as well as most of system settings. This will require a service technician from a dealer with connections to RICOH.
Feb 25, 2009 | Ricoh Aficio 450 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Mar 18, 2008 | Ricoh Aficio 1013F Copier
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
41 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
