I use my cc a lot, but trying to help a friend understand hers, I somehow messed mine up. Before this all I had to do was press the cc button and turn it on. Now how do I get that back??
My tv is a Zenite H25D34Y2
Posted by Dixie Cockrell on
Franco Dosil
    Top Expert:
  • Televison & ... Master
  • 10,535 Answers
Hello Dixie, it is very possible that the CC does not work for you, from the remote control, for failure of the CC button on the remote, try to enter the menu and look for the CC function and try from there if it changes, if it does, it means that the CC button on your remote control works poorly
Try replacing the remote
Greetings Franco Dosil
Hola Dixie, es muy posible que no te funcione el CC, desde el control remoto, por falla del bot?n CC en el remoto, prueba ingresar al men? y buscar la funci?n CC y probar desde ah? si cambia, si lo hace, quiere decir que el bot?n de CC de tu control remoto funciona mal
Prueba reemplazar el remoto
Saludos Franco Dosil
Posted on Jun 15, 2019
5 Related Answers
Anonymous
  • 579 Answers
SOURCE: Sharp LCD can't turn on
Bummer, one month out of warranty. This is why I always recomend keeping expensive, high tech stuff under warranty.
First thing to do is buy and download the service manual from servicemanual.net and find out what the fail code of 1 blink means.
Posted on Dec 31, 2007
Anonymous
SOURCE: Closed Captioning comes on every time i turn on the tv!
Apparently the 2002 Sharp model TV that I purchased has the closed captioning by default if the mute button is engaged. So there is no solution for my particular model, it has been built in this way. The only solution is not to use the mute button and lower the volume instead.
Posted on Jan 06, 2009
Anonymous
  • 463 Answers
SOURCE: i have a philips magnavox tv with the original
You're not doing anything wrong. Your TV is somehow turning the cc on "all by itself". Some bit is getting flipped inside the TV, turning the cc on.
either that or there is some sort of rf or ir interference near the TV that is mimicking the CC button on the remote.
Have you pressed the cc button on the remote, verified the cc is "off" on the TV and then removed the batteries from the remote for a while to make sure there isn't something hinky with the remote???
Posted on Feb 27, 2009
Anonymous
SOURCE: I BOUGHT A BRAND NEW TORO LAWNMOWER, MODDEL 20330,
don't waste time looking for the primer bulb. probably wont work anyway if its over 6 months old and repairs probably wont do any good either. bad design for a primer system.
Posted on May 03, 2010
gopakumarg43
  • 76390 Answers
SOURCE: I can't turn off the
Hello
In the Closed Caption system, there can be more than one caption service provided. Each is identified by its own number. The "CC1" and "CC2" services display subtitles of TV programs superimposed over the program's picture.
In the Closed Caption system, the "Text1" or "Text2" services display text that is unrelated to the program being viewed (e.g., weather or news). These services are also superimposed over the program currently being viewed.
Posted on Feb 20, 2011
My sound up and lock button are sort of switched on my ipod touch...for example: i press either key if pressed it will turn the volume will turn up one point and then lock..if held it will turn up the...
The volume is messed up from the jailbreak. To un-jailbreak it, plug it in, and go to itunes and restore the Ipod touch. Careful, as this will DELETE everything on the Ipod, but its the only way to fix this and any other jailbreak issues. You can always go back and reinstall everything after you have restored the Ipod.
Oct 17, 2010 | Apple iPod touch
I have a philips magnavox tv with the original remote. closed caption constantly (writing script)comes on tv screen, even though the remote has a cc button,i press it until cc off comes on, the cc goes off...
Feb 27, 2009 | Televison & Video
Closed caption option on moterola cable box
I woke up this morning to try to win this fight I have had for days with my damn tv, our 3-year-old daughter somehow turned on the CC on the DVR box and we had no idea how to fix that.
I read the suggestions listed here and I wanna say a big huge THANK YOU to the person who suggested that to turn off the cable box thgen hit menu button and it would be there...your so right! THANK YOU again......
from a frustrated Mom in Maine
Jun 11, 2008 | Motorola Televison & Video
Cc button
Press "cc" again, and that should do the trick...accordianman
May 28, 2008 | Olevia LT32HVE 32 in. LCD Television
GPX MW3837
mine did the same thing (I just got it today). I just kept messing with the on off button and somehow it came on.. Now I can't get it to shut off.. the only part of that button that seems to work is hold and unhold now.. lol.. I cant see letting my battery wear down all the time leaving it on.. so I may be returning mine so i can get a replacement.
May 22, 2008 | GPX MW3837 MP3 Player
OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Apr 18, 2008 | AOC LM729 17" LCD Monitor
Can't turn subtitles off
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Ps3 menu
have tried turning off the auto game start
Dec 17, 2007 | Sony Playstation 3 (PS3) Console
27 INCH OLEVIA LCD FLATSCREEN
I had the same problem....
The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
The CC button should work now.
Sep 07, 2007 | Olevia LT32HVE 32 in. LCD Television
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
