Question about Creative Labs ZEN Vision:M Digital Media Player
My fm radio stopped working on my creative zen vision, and the display is all messed up. It also freezes for about 20 minutes when I turn it on. After 20 minutes, it will play normal, but it freezes immediately on start up. How can I fix these problems?
Posted by elamaree on
YourZEN
  • 820 Answers
Support for Zen Vision M on this site:
One of the Knowledgebase Solutions for "freezing" gives this answer:
Solution ID: 64087
My fm radio stopped working on my creative zen - dot-clear.gifSolution ID # 64087 --&My fm radio stopped working on my creative zen - dot-clear.gif/uploads/imageMy fm radio stopped working on my creative zen - dot-clear.gifif" alt="dot-clear.gif" class="h_mi" />dot-clear.gif -->
Player is Freezing
Keywords / Key Phrases: freeze, freezes, freezing, hang, hanging, freezes at creative logo, at docked screen, rebuilding library screen, playing audio files, switching to other functions or menus while shutting down, freezes at recovery mode, freezing at music playing now screen
  1. Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
  2. Refer to the article below to access the recovery mode and perform a Clean Up.
    SID 64088: Accessing the Recovery/Rescue Mode of your Player
    Note:
    1. Clean Up scans a player\'s hard disk/memory card and removes any invalid links from the music library. It does not affect the working music files at all. It is recommended that you perform "Clean Up" first before formatting or reloading the player\'s firmware.
    2. It is advisable for you to clean up your player regularly if you are frequently transferring files from you computer to your player or vice versa.
Last updated: June 16th, 2009
Posted on Aug 08, 2009
Creative Zen Vision M Display messed up
Sounds like the screen whend under some pressure and cracked, you'll have to replace the screen.
See how to open up your zen at this site.
Aug 27, 2009 | Creative Labs ZEN Vision:M Digital Media...
Jammed Creative Zen Mozain when FM radio is idle
Click Here for Creative Software and manual
You may need to reinstall the firmware on your Zen to get it working properly again. The above link will take you to the creative website and the exact page you need for your software and manual downloads.
Feb 03, 2009 | Creative Labs Creative Technology Zen MP3...
How to recover the FM stations
From the FM Radio option, there is a "scan for stations" option.
Jan 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
No radio
If you go to the menu, and hit system, then hit display settingsand finally hit configure menu it should bring u to a checklist page....if u scroll down to FM Radio, that box should be checked...if not than check the box and bac out bac into the menu screen....FM radio should now b there!
Jun 21, 2008 | Creative Labs ZEN Vision:M Digital Media...
CAN'T FIND THE FM TUNER IN THE MENU
  • The player may have to be formatted, which will erase the contents of the player. If you would like to manually update the firmware, please see below.
  • Please note that some firmware updates may format the player. Please read the installation notes for the firmware update before downloading it.
The MP3 Player Recovery Tool can be downloaded at www.creative.com/mp3playerrecoverytool.
Jun 20, 2008 | Creative Labs ZEN Vision:M Digital Media...
FM radion and Creative Zen Vision M stopped working
Need to replace headphones first - if that fails, then the headphone jack is bad and will need to be replaced. Sorry.
Mar 21, 2008 | Creative Labs ZEN Vision:M Digital Media...
FM Tuner
System > Display Settings > Configure Menu
Scroll down about 2/3 the way down and make sure that FM Radio is checked.
I hope this helps - creative does have a know problem with this
Jan 01, 2008 | Creative Labs ZEN Vision:M Digital Media...
Freezes everytime I turn it on
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 20, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen Vision M freezing during music upload.
Try to add your music a bit at a time instead of your whole library at once. That will freeze it. You can also try sync with Window's Media Player, which works a lot better than the Creative software.
Nov 29, 2007 | Creative Labs ZEN Vision:M Digital Media...
Fm tuner
I justed posted above but you can probably ignore it. It seems we are not alone... http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=164959&view=by_date_ascending&page=1
Jan 04, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
aliasger yq
Jean Sintulaire
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
