Question about Amana Refrigerators
20 yr old Amana mod SQD26VW.Freezer leaves ice cream soft. During early morning temp is average of 10 but stays around 22 during day,removed bottom panels and vacumed from f & r
Temp dail is set on 7 (coldest)
Posted by Billy Layton on
B Bizzy
    New Friend:
  • 26 Answers
Theres a few solutions that could fix this. 1st I would let the unit thaw out could have ice built up on the air passage that wont allow the air to travel freely. Some caused by not having a good seal around the door.
Posted on Jun 15, 2019
4 Related Answers
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: In my Amana side-by-side refrigerator the ice
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Ed Saucier
  • 52 Answers
SOURCE: amana model SXD26VW. Freezer
You need to have a Technician have a look at it. I suspect you have a coolant leak. You need to have him run a check on it. Do not do this yourself as it can be very dangerous for someone who does not know what to do.
Posted on Jun 08, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Makes one tray of ice
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Posted on Jul 03, 2011
imufo2
Leo Ponder
  • 3773 Answers
SOURCE: amana scd25tl is making ice
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 07, 2011
My ice cream maker spins but not making icecream
* Ice cream makers are small tub partial filled with cream, sugar, and flavor.
* This cream tub is placed inside a larger bucket containing ice and salt (usually rock salt). The salt makes the melted water almost as cold as the ice. (colder than regular unsalted water)
* Creme in contact with the metal tub gets frozen and creates a layer of frozen creme around the tub.
* The frozen creme is soft due to the fat in the creme preventing the liquid from freezing hard.
* Scraping away the semi frozen cream allows more liquid cream to freeze on the cleaned sides of the inner tub.
* with continuous scraping the cream will form a semi frozen "Milkshake" like thick liquid. It will not harden as the large ice bucket would have melted all the ice by then.
* Remove the semi-frozen cream. Serve immediately or pack in container to continue freezing cream. It should harden when left over nite in freezer.
* Using bucket; https://www.youtube.com/watch?v=o_IFfVdOE2g
* Using bowl; https://www.youtube.com/watch?v=t7aUHywPnog
* Using Ziplock; https://www.youtube.com/watch?v=y-69y9GsS_4
* Enjoy!
Aloha, ukeboy57
Aug 28, 2018 | Ice Cream Makers
Ice block
There is some cooling in the freezer which is allowing the temp to raise above freezing for a brief period. Check gaskets and or the temp setting. Is ice cream hard or soft. Ice cream freezes at around 15-18 degrees. My guess is that the door gasket is allowing air inside the box.
Feb 03, 2013 | Samsung RF265AA Bottom Freezer French Door...
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Hi, i have a kenmore refrigerator ,ice cream is soft temp read below 10 deg f could the defrost be cycling on too long
Maybe, How long does your defrost stay on? Make sure the evaporator fan turns off during defrost. Also make sure there is nothing blocking the coil so that you get good air movement. If you pack your freezer the cold air will not circulate to pull down the load temp. You also look at the door gasket and make sure it has a good seal. This is done with a dollar bill half out and pulled through a closed door. Move it around to see if if pulls out easy and there is a leak.
I hope this helps.
Apr 20, 2010 | Refrigerators
We own an Amana bottom freezer; Mod.# BC120TW, Ser # 9708176268. It is approximately 10 - 11 years old. The freezer is not getting to a low enough temperature. We have soft ice cream etc. I have cleaned...
If it is constantly running, (compressor and the fan inside of freezer) then the thermostat is working, more than likely you have an inefficient compressor or a low charge in the sealed system due to a refrigerant leak. Touch the compressor, is it almost too hot to touch? Do you hear a buzzing and clicking noise every so often? If you can answer that for me, I could better diagnose it
Jun 15, 2009 | Refrigerators
This is a simple question. What is the average
Not so simple actually. Depends for long lasting, deep freeze, meat ect you want 0 to -4 Farenheit. For Ice cream (non-defrosting) soft 20 to 24 degrees firm 15-19 degreees, hard same as meat. For defrosting models stick with the 0 to -4 as otherwise ice cream and other liquids will actually melt during the warmest part of the defrost cycle. I believe that is a self defrosting model so I'd stick to 0 degrees farenheit average.
May 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Freezer temp flucations
I am wondering how often you are noticing this and if your ice cream is ok?
GE controls are different in the fact that they give you the temperature it is and if you hit the buttons then it will give you the setting you have. For example it might read 10' and you hit a button and then it will read 0' or whatever you have it set to whereas most controls only say the temperature that you want.
The fridge has an adaptive defrost and typically will go into defrost every 8-10 hours of run time. it is not uncommon for the temp to spike during this process and it is not high enough for long enough to start defrosting any food.
Ice cream is the breaking point! for most brands it will be rock solid at 0'.. soft at 5ish' and soup between 10-15'. I only buy breyers and it has a high fat content so it is usually very scoop able at 0' but most brands with ingredients you can not pronounce will be rock solid at 0'.
So.... if it is a short term thing and your ice cream is fine then I would chalk it up to opening the door during, or shorty after, a defrost cycle. But if it a regular thing and your ice cream is mush then I would start by making absolute sure that nothing is stopping that drawer. IE: look for boxes with smushed corners especially in the lower bin.check for anything under the drawer such as a pack of bacon or a lean cuisine (you would be surprised how often I see this) and lastly make sure that the coils are clean. If you have pets they can get blocked up causing inefficiency. you have to pull the unit out and take off the back panel to do this.
Jan 28, 2018 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
