Question about Epson Office Equipment & Supplies
How can i remove ink pad in epson l 382 - Epson Office Equipment & Supplies
Posted by irutamageno ernest on
Archers Smith
    Habit-Forming:
    New Friend:
  • Epson Expert
  • 180 Answers
If you are face epson printer related any problem you can visit our site.https://www.epsonprintersupport247.com/how-to-setup-epson-surecolor-p5000-printer/
Posted on Jul 19, 2019
5 Related Answers
Rommel Balcita
  • 749 Answers
SOURCE: need replacement waste ink pad
Hi...
so bye bye waste pad... can't find any replacements but this is my recommendation for you a waste tank... It's what I did on my 2 Epson Printers... Click the link to get the idea...
waste tank
Or you can use some tissue papers to replace what was thrown away.
Happy Fixya...
Posted on Feb 28, 2009
websnail
Martin Smallridge
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
Anonymous
  • 7 Answers
SOURCE: Dirty Waste Ink Pads (Epson Stylus R285)
Remove to top cover and replace the ink pad with a new one. You can get these pads from a place called pudsey computers www.pudseycomputers.co.uk
Posted on Mar 15, 2010
Tariqul Islam
  • 120 Answers
SOURCE: how reset ink pad without removing any parts,
jast go to:
http://tricks-collections.com/resetter-epson-tx121-t13-t1100/
and find resetter. Download and run it in your pc. at these time reset your printer.
Thank you.
Posted on Jun 30, 2011
south_town
south_town
SOURCE: INK PAD FOR MY EPSON ME320
where i can find the reset button of epson me 320 printer?
Posted on Sep 20, 2012
Epson l200 ink pad error
epson L200 ink pads error Epson L200 is an All-In-One printer, All-In-One printer is a printer unit has multiple function as Scanning, Photocopying, and printing. Epson L200 comes with 6 ink bottle consist of 3 Black Ink, and colored ink, 1 bottle for Cyan, 1 bottle for Magenta, and 1 bottle for Yellow Colors pls check epson L200 ink pads error reset http://www.2012teamtech.com/epson-l200-ink-pads-error
Dec 25, 2013 | Epson L200 Original Continuous Ink Tank...
The printer's ink pads are at the end of their service life. Please contact Epson support.
Nov 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
My printer is epson tx650.the problomis that it say 'the printer's ink pad is at the end of their service life'. please assist me with the solution.says RAKITA
Sadly the other solution is the usual corporate party line regarding "Parts at the end of their service life" and is intended to encourage printer owners to purchase new printers.
The reality is quite different.. Epson printer are generally capable of upwards of 3 to 10 years or service with minimal care unless the printer is being hammered 24/7 with almost constant printing, which is very unlikely.
Waste pads however are an achilles heel that do need some form of action to either replace or work-around to resolve.
The options available are either:
1. Go to a service centre where it is indeed prohibitively expensive to have the printer disassembled to replace the pads and have the waste counter reset.
OR..
2. Get an external waste ink kit to redirect any waste ink to an external tank (it doesn't remove the current pad contents) and obtain the relevant tool (either a compatible AdjProg service program) or WICReset tool with a key (one needed per reset) so you can reset the printers internal waste ink counter.
The cost of the latter option is around 20-25(GPB) total (including shipping) so compared to the tooth sucking Epson Customer "Care" option it's not exactly rocket science as to which is more cost effective.
Please ignore the rubbish about other parts being near the end of their service life... About the only other thing to note is that the printer gears might need a little grease but beyond that and flimsy plastic paper guides the printer can easily last 5 years with a little care.
Mar 05, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson stylus photo rx685 the problem is, waste ink pad in the printer is saturated, I have removed all the wested ink in the priter, but is the same problem that am experiencing. Please help me solve this...
go to www.octoinkjet.co.uk/wib/ to download one of their inkjet ink pad reset utilities. It may just solve your problem. I couldn't clean or replace the ink pads on my epson RX700, so I bought their special adaptor kit. It solved the problem for me. If you already have cleaned the ink pads, maybe you can just download the reset utility. I hope it works for you.
Jul 07, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
Nov 17, 2009 | Epson Office Equipment & Supplies
Need to replace waste ink pad epson C88
open up the printer and remove the waste hose to the out side of the printer and into a bottle.
Mar 25, 2009 | Epson Office Equipment & Supplies
C46 printer
I could not find the manual, but I hope this helps:
I'm not sure if the waste ink pads are in the same place as the c45, but i hope this helps.
Locating the waste ink pads was pretty easy. First of all you have to dissasemble the case, then remove the paper slot. To do this you have to unscrew three or four screws (at least in my c45) that keep the paper slot attached to the printer. After doing this you will see the ink pads, they are at the bottom back of the printer. Mine has four of them with an "L" alike shape.
Clean them with plain water, then let them dry a couple of hours until all the moisture is gone.
I advice you to remove both ink cartidges before doing this because an strange thing happened to me.
After removing the ink pads i cleaned the ink pad container (you'll see the little tube that drains the "waste" ink from the cartidges to the pads) then a couple of hours later i found that the container was full of ink!! confused1.gif . And of course, the ink cartidges were almost empty upset.gif
That happened because i didn't remove the ink cartidges before doing the whole process. I have no idea why that happened but probably by removing them you'll avoid that.
Epson resetter software can be found at http://www.ssclg.com/epsone.shtml (the link to download it is located at the bottom of the page)
One last thing, to reset the waste ink counter you have to go to "Protection Counter" menu and then click "Reset Protection Counter".
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 19, 2008 | Epson Stylus C46 InkJet Printer
EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Mar 25, 2008 | Epson Stylus 2200 InkJet Photo Printer
129 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
