Question about Lexmark Office Equipment & Supplies
Where can I find a service-Manual for Lexmark X9575? I Need to open the printer for cleaning ink spread by a bad cartridge. Thank you!
Posted by Klaus Merle on
Terry
  • Lexmark Master
  • 11,377 Answers
5 Related Answers
Anonymous
SOURCE: change ink cartridge
I just did it a few minutes ago and it's pretty simple. Just grab the thing right in the center, above the print tray (there's a little handle) and pull the top up. The ink carts will be right in there (towards you, on the right) just pull the one you need to replace out, directly towards you, and then pop the new one in. There are little notches on it so you can't put it in backwards/upside-down or anything, and there's no latch or anything physically holding the cartridges down
Posted on Dec 18, 2007
Anonymous
  • 564 Answers
SOURCE: Service/repair manual
sure..get a new control board..since that one is literally toasted
Posted on Aug 20, 2008
wayneard
Wayne Mineard
  • 1901 Answers
SOURCE: I cant figure out how to change the ink cartridges on my lexmark
On an X4850 the whole top of the printer opens up to reveal the cartridge carriers. Press down on the latch of each side to reveal the cartridges.
Here is a link to the User guide: X4850 User Guide It is described on page 94.
Posted on Nov 20, 2008
Jennifer Grant
SOURCE: ink problems lexmark x2500 printer
lexmark ran out of ink replaced cartridge. still saying i am out of ink and wont print anything
Posted on Dec 04, 2008
vendetta1
  • 5 Answers
SOURCE: x5470 Lexmark printer
i refilled my lexmark 24 color cartrgide but now the printer does not want to read the cartridge, any help on resetting the thing before i chuck it trew the window
Posted on Apr 23, 2009
I have a Lexmark X9575 all-in-one printer. When I refill the ink cartridge the printer still says it is empty. How can I reset the printer to think the cartridge is full again?
Lexmark Printers will not recognize Refilled Cartridges, The Fuse inside the cartridge blows and makes the cartridges Unusable is there is an attempt made to refill one!
Apr 08, 2013 | Lexmark X9575 InkJet Printer
No installation cd x9575 lexmark printer
You can download the Lexmark printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Sep 30, 2012 | Lexmark X9575 InkJet Printer
Printer ask for cartridges
turn off your printer...then replace new cartidges.after replacing cartridge restart printer...always when you want to change or replace cartridge/Drum/fixing/belt trun off your printer...
Jul 12, 2012 | Lexmark X9575 InkJet Printer
Paper keeps getting jammed
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.
Nov 23, 2010 | Lexmark Office Equipment & Supplies
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
How to free carriage jam on lexmark X4550
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.fix Lexmark Carriage Jam .
Sep 18, 2010 | Lexmark Office Equipment & Supplies
Does the Lexmark X9575 print automaticly 2 sided with no manual feed. I have a 15 page document doulbe sided. How do I print this without babysitting the printer. Thank you
Your model supports automatic duplex printing using letter and A4 sizes ONLY. If you want to print two-sided documents on another type or size of paper, use the manual duplexing method.
1) With a document open, click "File" > "Print..."
2) Click "Properties" or "Preferences" or "Options" or "Setup" depending on your system
3) Click the "Advanced" tab
4) From the "2-Sided Printing" area, select the 2-Sided Printing option and then select either the "Sideflip" or "Topflip" option (sideflip is the setting most often used)
5) From the drop-down box, select Automatic.
6) You will see an "Extend dry time" option, which allows extra drying time between sides when you are printing on both sides of the paper. The Automatic 2-Sided Printing option affords enough time for the ink to dry on supported paper types in average air humidity. Under conditions of high humidity, or if the normal drying time does not allow the ink to dry completely, you should select Extend dry time.
7) Click <OK> to close any printer software dialogs that are open. This will take you back to the General Print screen.
8) Click "Print"
Note: To return to single-sided printing, return to the Advanced tab. From the 2-Sided Printing area, clear the 2-Sided Printing check box.
Jan 14, 2010 | Lexmark X9575 InkJet Printer
Need to install a new printer cartridge
Hey,
you can get the user manual for your printer from this page
http://images.lexmark.com/publications/pdfs/2007/index/en.html
just find your model from the page and you will be taken to them , you will also need a pdf reader on the computer.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Let me know if you need anything else.
Thanks,
Ekse
Mar 17, 2009 | Lexmark X9575 InkJet Printer
Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Nov 19, 2007 | Lexmark Color Z35 InkJet
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
