Question about Sharp Office Equipment & Supplies
My Sharp photocopier AR-6020v display E7. and can't make copies what is the problem?
Posted by Bheesam Sonwani on
JP Meneide
    Dedicated:
    Visited the website for 20 consecutive days.
  • Sharp Master
  • 483 Answers
Hello Bheesam,
Turn off the power switch, wait about 10 seconds, and
then turn on the switch again. If this does not clear the
message, write down the code (Main code and sub
code exists.) that appears and then unplug the power
cord and contact your authorized service Rep.
Here is a link for you:
https://www.manualslib.com/manual/885094/Sharp-Ar-6020.html?page=111#manual
Posted on Jun 16, 2019
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: On a Sharp AR-157E, I
Finally tracked down an error code list showing the errors were associated with the CCD and scanner
Posted on Jul 10, 2008
Anonymous
SOURCE: E7 problem
Sharp AR-5132 won't print
Error code E7 13
It will warm up like it's about to print or scan then error code E7 13
please give any advice
Posted on Nov 03, 2008
Everett Lin
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
Anonymous
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
SOURCE: My Photocopier displayed error H4 on the screen
Dear sir
H4 signal is fuser unite problem please call a technician they solve this problem.Just we serve problem location because i am not live your area.
Thanks
Tareq
Posted on Aug 13, 2009
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error Code E7-11 on a Sharp AR-287 photocopier
This code is related to laser unit functioning problem. Power the machine off and on and if it appears again, do the following;
  1. Open document glass and clean inside mirrors and document glass with a clean dry soft cloth and test.
  2. Check flat cable that connects copy lamp and attach firmly from the main board.
  3. Replace the laser unit if the above fails.
Ask for assistance if you doubt from a qualified technician and you will succeed.
Dec 20, 2010 | Sharp AR-M205 Copier
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Copier turns on but will not copy
There should be a sub code for the E7. Depending on the sub code is what the error exactly is.
Jan 02, 2009 | Sharp Office Equipment & Supplies
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Apr 28, 2008 | Sharp AR 201 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
