Question about Samsung Audio Players & Recorders
Our series 8 Samsung QLED TV is connected to our Onkyo receiver through the one connect box We can control switching the Onkyo thru the Smart Remote but not the volume Any ideas?
Posted by Sandi Clarke on
5 Related Answers
kipperbush
SOURCE: Unable to configure SAMSUNG 3241D TV with ONKYO remote (RC-608M)
Check out
http://akamaipix.crutchfield.com/Manuals/580/580HTS780B.PDF
Posted on Jun 07, 2008
Anonymous
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
Anonymous
SOURCE: Remote Control Repair
Open up your controller and look for 4 Wire! Green, light green, blue and yellow! Green and yellow is for power i guest! Light green and blue is for bass. 4 together max everything!
Posted on Feb 16, 2009
Anonymous
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
Anonymous
SOURCE: Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Posted on Sep 13, 2009
I have HarmanKardon receiver AVR 230. I have sound thru the speakers for all equipment except the New Samsung 4K QLED TV.
The QLED television will only recognize what is connected to HDMI ARC. A digital optical connection wont provide that functionality.
Feb 25, 2018 | Samsung Audio Players & Recorders
Onkyo tx sr502vreceiver wont send sound out when trying to play a cd. Hooking up to samsung smart tv that has no s video or optical output connections. HELP ! ! !
Hi Denni, the TV should not be a factor. Is the CD player connected to the receiver. It should be playing out the receiver speakers. Thank you, Onkyo USA
Nov 30, 2016 | Onkyo Audio Players & Recorders
How can I configure a Samsung TV (6350) remote to control my Onkyo txsr605 volume?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Jan 04, 2015 | Samsung 6350 Series UN55F6350 55" LED...
How do I connect Samsung smart TV to a Yamaha receiver and get sound to come out of surround sound speakers?
Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
Aug 07, 2014 | Yamaha Audio Players & Recorders
Connect Sharp LCD tv to Onkyo TX8011 Receiver
The Onkyo TX8011 is a Stereo Receiver. Two ways to connect:
1) The HD Cable box should have an audio out (typically red and white). Connect this to the Obnkyo CD input (red and white). The volume may be controlled with the Cable box remote or Onkyo remote. The TV volume may be muted or ON.
2) Connect LCD TV's audio out to Onkyo TX8011's CD input.
This is not a great way to set up, as the TV volume, when moved high, will attenuate (over load) the amplifier, leading to a jarring sound on the speakers. To avoid this, the TV volume should be ALWAYS FIXED low.. say about 30%. Only the Onkyo's volume should be adjusted while watching.
Hope this helps.
Nov 20, 2013 | Onkyo Audio Players & Recorders
My Aeros remote control turns on the cable box, Samsung Tv and Onkyo receiver without a problem. When I go to Main and power off, only the Cable Box and Onkyo receiver turn off. The Samsung TV does not...
1= reset the code again download from www.fitness.manualsonline.com
2= retight the spring contacts batteries with pliers for better contacts
3= clean the contacts batteries.
4= open the r.control for clean the keypad switchs, from dirty, corrosion or oxide. remember they send infrared signal to the receiver microcontroller.
5= if the problem persist you must go to the repair shop TV for fix it.or replace.
God bless you
Jul 14, 2012 | Universal Remote Control MX-850 LCD Remote...
Sep 12, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Jul 02, 2009 | Onkyo TX-SR605 Receiver
Tivo HD will not record when Onkyo HT-SR800 is off
Do you want to run all your cables thru the receiver? There really is no benefit for you to do this since that receiver doesn't handle HDMI audio nor do any kind of component to HDMI conversion. Might as well connect your tivo box directly to the TV with HDMI. You'll have to switch inputs on your TV between the cable box, but its not a big deal.
Feb 20, 2008 | Onkyo HT-SR800 System
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
