Question about The Computers & Internet
My charge 3 shows the correct time but other functions don't work
Posted by Don Lindquist on
Dennis
    Top Expert:
  • 1,052 Answers
Try restarting the Charge 3.
Plug your USB cable into a computer or listed USB charger. Plug the other end into the back of the tracker. Make certain the pins click into place.
Press and hold the button on the tracker fir 8 seconds, then release the button.
When you see the smiley face and it vibrates, the tracker restarts.
(Restarting does not delete any data.)
Posted on Jun 15, 2019
Gateway 7322 Notebook. Can't get the battery only
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 09, 2012 | Computers & Internet
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Laptop battery plugged in,not charging
Try draining the battery completely and then charge it fully with the laptop switched off.
If you don't know how to drain it out completely, please let me know.
Jul 02, 2017 | Toshiba Satellite X205-S9359 Notebook
Casio TK7000 Cash Register. I have all sales appearing as CAID and none in CHID or CKID or CRID. I have checked that Program 3 Address code 08 is set correctly. What else could be affecting this?
If the sale is finalized correctly, cash, check, etc., then cash in drawer, credit in drawer, etc. should show up.
If you don't have the cash, check, credit buttons, you can program them in like this:
PGM, then 4, followed by the desired Function Key Code, and then press the Key to assign this function to, followed by pressing the Subtotal button to save.
FUNCTION - CODE - CHARACTER
Cash Amount Tendered - 001 - CASH
Charge - 002 - CHARGE
Check Tender - 003 - CHECK
Refer to the following PDF document for assigning function keys, and a list of the function codes:
http://www.4shared.com/document/2poxz4Z8/Casio_TK-7000_Key_Allocation.html
If you need a User's Manual for this Cash Register, here it is:
http://www.4shared.com/document/2YONddyN/Casio_TK-7000_Users_Manual.html
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 06, 2011 | Casio Parts Cash Register PC Desktop
I have a compaq cq40-502au..i having a problem with my laptop,i can't start up my laptop,last time i used it,the battery icon showing low battery for my laptop.Then i charge it,after 2-3 hour's i came back...
there is a possibility the battery has shorted out, try removing the battery and powering it on by a/c power if that works get a new battery, if not get a new charger
good luck
Feb 25, 2011 | Computers & Internet
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Fix the hands correct with the dejital
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are;
hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t
have the hands exactly opposite etc. This can all be fixed. The Synchronization
function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Nov 16, 2008 | Tissot T-Touch T33759851
Time setting
Make sure unit is off by pressing and holding the 'Source' button. Wait 3 seconds, and then press and hold the 'Source' button. Do Not Release the button! A display reading "Initial" will show. Then use the arrow buttons surrounding the 'Source' to set clock. The 'Function' button isn't involved, dispite what the manuel states.
Nov 28, 2007 | Pioneer DEH-P3900MP CD Player
Laptop shuts off when unplugged, battery is fully charged
Chosenone, Even though the battery meter shows it fully charged I doubt it?s correct. Over time rechargeable batteries loose their ability to store power. How long depends on the battery manufacturer and how well you treat it but you can consider yourself fortunate if your battery lasts three or four years. Beware of people who suggest you take apart your batter to bypass the safeties or replace old battery cells. Defective or improperly handled batteries can overheat and cause fires when you least expect them. Let us know if you have any more questions and please don?t forget to rate this post.
Feb 23, 2007 | Compaq Presario 1200 Notebook
Computers & Internet Logo
703 people viewed this question
Top The Computers & Internet Experts
gardoglee
Level 1 Expert
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
