Question about Refrigerators
Have a leer freezer and it's not getting cold??
Posted by Anthony cusimano on
The freezer is great but the refrigerator section will not get cold
Refrig gets cold arir from freezer. Check the control that diverts cold freezer air into refrigerator compartment.
Jun 17, 2017 | Refrigerators
Freezer part are too cold
Why is my freezer too cold? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
The freezer freezes the food rock hard. There is frost throughout the freezer part. Today I noticed a half inch of ice on the bottom of the freezer. I cannot slide out ...
[Appliances] Freezer is too cold? - Home Improvement ' DSLReports ...
www.dslreports.com > ... > Home Improvement
DSLReports
Jul 31, 2014 - 16 posts - ‎12 authors
I'm guessing food won't last as long if it's too cold? ... Freezer is too cold? I get a build-up of ice in some of my frozen items in my freezer. .... If no recent changes, then maybe you are seeing only part of the frost build up. Maybe ...
Freezer to refrigerator vent frozen (1) - YouTube
? 1:30
https://www.youtube.com/watch?v=8g_39UHYeEA
Feb 9, 2012 - Uploaded by Dal4us
Our freezer was getting too cold and refrigerator was not cold. ...Refrigerator Repair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool ...
Jan 03, 2016 | Whirlpool W8RXNGMBD Universal Silver 17.6...
Anagram solver
can u make a word from these letters f f y i t t w o plz.
Apr 04, 2012 | Office Equipment & Supplies
The refridgerator has not been cold enough, the freezer is fine what should i do?
The refrigerator itself get cold air from the freezer. There is a small opening that lets air from the freezer to go to the refrigerator area. make sure the cold air from the freezer is getting there. Sometimes there might be a restriction on this vent therefore the refrigerator is not getting enough cold air from the freezer.
Jun 28, 2009 | Amana AFD2535DES French Door Refrigerator
Freezer Problem
Make sure condenser is clean.
May 29, 2009 | Summit Commercial Freezers
Should freezer compressor get very hot when waiting to get cold
it is normal for the compressor to get warm as long as the freezer is cold
Apr 24, 2009 | Refrigerators
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
