Installed usb ovhd flash drive, worked fine for a week, now says error during recording
Posted by Trevor Derbyshire on
Steve Si
What fix do you want?
1. Recover files
2. Reformat the flash drive and make it work
3. 1+2
4. Check Flash drive to see if it is faulty
Posted on Jun 16, 2019
5 Related Answers
Anonymous
  • 208 Answers
SOURCE: usb flash drive 2 gb
Hi ...
When that happen try going into the device manager area >>> start >>>
control panel >>>system >>> hardware tab >>> device manager , now notice
your usb controllers area , its mostly likely open and if so ?
See if you notice a little yellow exclamation mark http://en.wikipedia.org/wiki/Exclamation_mark by it , if so , right click on it
and select delete , then highlight your computer name http://en.wikipedia.org/wiki/Naming_scheme on the very top of the
devise manager , select " Action " and then select " scan for hardware
changes , at this point your compute should now notice your usb devise , by
the way make sure when you are performing this that your usb devise is plug
in , See if that helps.
Else refer to this website http://www.uwe-sieber.de/usbtrouble_e.html
This site every issue related to USB device.
I am sure this will surely fix your problem.
Thanx for using fixya,
Bye.
Posted on Sep 26, 2008
Anonymous
  • 928 Answers
SOURCE: USB Flash drive suddenly not recognized in WinXP
Ive included here a link that helped me fix a problem with my flash drive that was giving the same problems. perhaps you could take a look at it.
http://www.hat.net/geeky/node/221
Posted on Oct 27, 2008
Anonymous
  • 4 Answers
SOURCE: During scheduled recording for 1 1/2 hours, chanell changes
I called panasonic and they sent me @ no charge a cd update that fixed my problem. I talked to
John @ 1-800-211-7262 ext 5070. He seemed very knowledgeable and spoke ENGLISH!
This cd may fix other problems for this model.
Posted on Jan 10, 2009
barez
  • 9 Answers
SOURCE: asus P5QC mobo won't recognize personal storage through USB
i have this problem too but i know if you disable usb2 in bios it will solve the problem but speed is too slow and i cant solve this problem (speed)
my email:[email protected]
Posted on Feb 04, 2009
jonsnell4
JonSnell Electronic
  • 31505 Answers
SOURCE: I need to boot Win7 by USB flash Drive created by a 2.5"FF SATA drive.
If you can tell your BIOS to use USB as the first boot device and the USB is from an ISO of Win7, it should work but your laptop won't be happy as the drivers may be wrong.
Posted on Dec 07, 2014
Testimonial: "I tried this but was unsuccessful, I am using Dell Optiplex GX280 small form factor desktop computer not a laptop. When I selected only USB bootable through CMOS setup, it didn't work and computer is not detecting any USB boot device."
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
A problem occured during installation and may not work properly
try to cancel first..then try to check your cables if they are connected property then re-installed if the problem still the same.better find some spare cables then try to re installed.
Aug 13, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Problem is occured during installation of USB Mass Storage Device An error occured during the installation of the device Data error(cyclic redundancy check)
Try uninstalling the USB root hubs in the device manager and then restart. They will reinstall upon the restart.
It may also could be a bad power adapter.
Dec 06, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
PNY 8GB Flash Drive - PC Will not recognize
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
Oct 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Oct 27, 2008 | Computers & Internet
Flash drive
Hi phun2008
Did your question get answered? (I'm not sure what "no thanks" was in response to.)
Your flash drives should work fine w/ Windows XP. They should be detected by the operating system as mass storage devices - plug-n-play - w/ no need for drivers installtion, etc.
You may, however, experience detection issues w/ them on systems w/ older USB hardware. If the flash drives are USB 2.0 drives, they will not be detected on systems running USB 1.1 or earlier - regardless of the OS (operating system) installed.
On the other hand, if they are USB 1.1 flash drives, they should be detected fine on both older and newer USB ports as USB 2.0 is "backward compatible".
I hope this helps.
BJ
Apr 03, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Ekse
Marvin
Marvin
