Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
I have a Panasonic cordless phone, Model KX-TGF350, that we accidentally blocked a important caller how do we unblock this caller?
I'm not sure how this happened unless it somehow happened when the phone was unplugged while rearranging the furniture and plugged back in when finished.
Posted by Lester Land on
Larry Ng
  • Uniden Master
  • 5,978 Answers
One if these old land line thing-a-bobs>?
LAND LINES:? sure it is.
most land lines (gee endless world wide and collapsing)
I you actual PHONE has caller ID blocking turn it off, RTM
read the manual on your phone.
if say using AT&T, land line (wild wild guess) you have special *Number to call and you must reset that using THAT>
answered for both ways, and I refuse to read your manual, on any landline-anything, mines CUT CABLE at the CURB.
Posted on Jun 14, 2019
5 Related Answers
Anonymous
SOURCE: phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
Posted on May 22, 2007
Anonymous
  • 106 Answers
SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Posted on Feb 19, 2008
Anonymous
SOURCE: UNINTENTIONALLY BLOCKED A REGULAR CALLER
no thanks - found my manual
Posted on Apr 11, 2009
Anonymous
SOURCE: Purchased Panasonic KX-TG6431 with total 4
Since you are asking me how did i solve it without you giving me any solution or hint,how do you expect me to tell you .You want money for advising me then i also need the same if you want solution.
Posted on Oct 07, 2009
Anonymous
SOURCE: Panasonic KX-TGA601CB cordless phone Was working
phone says move closer to base
Posted on Jan 28, 2010
I have a panasonic phone system kx-tgf350. On caller id shows line in use when a friend of mine calls. She is the only one this happens with. Any suggestions?
Either her home phone is ex-directory - unlisted, or her mobile phone is set to not show caller ID. A lot of business supplied cellular phones have this setting set by IT Admin.
Jun 06, 2018 | Panasonic Lands Phones
Manual for Panasonic model KX-TGF370 cordless phone
GO SEARCH IT ONLINE AND PRINT THE PDF . FREE
Jun 08, 2017 | Panasonic Lands Phones
How to operate panasonic phone model kx-tgf350
do a google search for "kx-tgf350 manual". If you dont have Internet, ask a friend or go to a library which has computers to use (usually free). Also, on the box, there may be an address or phone help to get manual.
May 20, 2017 | Panasonic Lands Phones
How do I ubblock a number on model kx-GL430 a Panasonic cordless phone
How do I unblock a number from my blocked calls list? - Panasonic ...
eng.faq.panasonic.com/.../how-do-i-unblock-a-number-from-my-blocked-calls-list%3...
  1. Cached
To erase a number from your blocked calls list;. Press [MENU] [#] [2] [1] [7]; Press the [?] or the [?] button to select the telephone number that you want to erase. ubblock number on model kx GL430 Google Search
Dec 11, 2016 | Panasonic Lands Phones
same as before Eula
  1. Cached
I have a Panasonic digital cordless phone model KX-TGE210. I accidentally block a number on my phone that I need to unblock to receive calls. Can you tell me how to unblock a number?
I have similar phone.
Press Menu then enter #217 to edit blocked numbers.
Use up or down arrow to scroll through numbers.
You can erase or edit blocked numbers.
For more info, see manual at: http://www.manualslib.com/manual/754430/Panasonic-Kx-Tge210.html?page=1
Mar 08, 2016 | Panasonic Lands Phones
WIFE`S CELL PHONE # IS BLOCKED, BUT IS NOT IN BLOCKED #S
Have her dial *82 before she dials the home number. If that works she has the cell phone set to block her number. *82 should unblock it for just that one call.
Aug 25, 2014 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
154 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
