Question about DeLonghi Heating & Cooling
I Have a Delonghi air cond. PAC N115EC after 20 min. it shut down and will not start. Red light is blinking above the start button, any thoughts??
Posted by Dale edwards on
5 Related Answers
Anonymous
SOURCE: Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Posted on Oct 02, 2008
Joe Hogan
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
Anonymous
  • 134 Answers
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Anonymous
SOURCE: need any user and -or service manual for delonghi PAC -75 U
Here is the manual
http://www.appliancefactoryparts.com/content/pdfs/123150.pdf
Posted on Jun 29, 2010
Anonymous
SOURCE: DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Posted on Sep 23, 2010
I have a new Delonghi portable AC PAC N115EC (11,500BTU), is it normal for the compressor in this particular A/C to be cycling on/off every 2 to 3 minutes?
If the room is cool, it sounds like the unit is operating correctly. It could be short cycling because the unit is over sized for the room being conditioned. if you can, increase to size of the load by opening a door into another room. As long as the refrigerant pressures equalize from high to low side internally and the compressor doesn't start up under load, you should be fine
Sep 10, 2016 | DeLonghi Heating & Cooling
How do i open the air grille of a Delonghi portable A/C , Model PAC N115EC
Should be hinged on one side. Pull the top or bottom and it should open
Aug 03, 2016 | DeLonghi Heating & Cooling
Delonghi pac an125hpek starts but then shuts down
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.If you need any other Air Conditioning Repair help. Check us out online.
Jul 23, 2016 | DeLonghi Heating & Cooling
I have a delonghi pinguino classic pac 25 i have to keep reseting red button on rear after aprox 2-5 mins as compressor cuts out &does not seem to restart but fan keeps going & red light with !...
Yes, bought one today, everything was fine until I put water in the tank, then it stopped after about 3 min. I think you will find that the previous owners (assuming 2nd hand) haven't de-scaled it. Take the rear cover off 5 self tap screws & you should see a lot of scale (calcium) you have to clean this away by whatever means you have (a hose nozzle) try not to wet the electrics too much. I had a wet vacuum aqua-vac I think &that helped but you can still do the same thing by hand, once it's fairly clean, it should run right, if i'm not wrong there will be a lot of calcium on the lower heat exchanger, you have to take off the plastic cover (2) self-tap screws & you will see what I mean, just scrape it away with the end of a toothbrush, no the end you hold, see you Richard
Jan 30, 2011 | DeLonghi Pinguino PAC-77E Air Conditioner
Delonghi pac w160a...''no water symbol'' stops on in airconditioning mode even though water tank is full
In the back of these units where the cord pulls out, there is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit. Make sure the coils are clean as well behind the filter.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 12, 2009 | DeLonghi Air-To-Air Portable Air...
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Delonghi FX400eco error code
I was trying to identify a error code, I found a manual online after a while
Sep 01, 2008 | DeLonghi Pinguino PAC-GSRU Air Conditioner
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Jun 19, 2008 | DeLonghi PAC85 Portable Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Sheldon Dedek
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
