SOURCE: sharp ar5316 blank pages printed and copied.
while standing in front of the copier open the Right door and then then flip down the Front door. Are the levers in place ? usually the front door will not close properly if not. Second take out the toner and look for a loosely hanging piece of plastic on it, give it a tug, does it seem to be a long peice of clear plastic? if yes yank it all the way out. It is a protective piece sent for shipping. It will be on ALL the toners you get. If not look at the right side door there is a back assembly there with either a black cylinder type roller or some strings. Are the strings broken , is the roller in place?
SOURCE: sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
If this does not clear the problem the fuser will need replaced.
SOURCE: SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
SOURCE: h3 code in sharp ar5316
Heat roller abnormally high temperature
press:
# --> interrupt --> clear --> interrupt
14 --> start --> 1 --> start
