Hi David, if your Kenwood does not turn on, check the power input fuse, to locate it, you should remove the lid
If the fuse is burned, replace it with only one of equal value, to avoid serious damage, if you change it and it starts to burn, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola David, si tu Kenwood no enciende, revisa el fusible de entrada de energia, para ubicarlo, deberas retirar la tapa
Si el fusible esta quemado, reemplazalo solamente por uno de igual valor, para evitar graves da?os, si lo cambias y se vueve a quemar, busca un servicio tecnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
SOURCE: need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF]
Cox Manual
File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
www.xdiv.com/remotes/ - 73k - Cached - Similar pages
www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
SOURCE: Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
SOURCE: Cannot hear any audio sounds or bleeps after installing Media 10
SOURCE: I have a kenwood cs-5.1 audio receiver and i would
you can find the codes on your universal remote manual
SOURCE: Can I Get a Kenwood RC-R0608 Remote to work with a Kenwood VR-206 A/V Reciever
i WILL BUY YOUR Kenwood RC-R0608 Remote
[email protected]
