Question about Furniture
My Wine Enthusiast 18 bottle 2 Temp frig is not chilling...can it be repaired?
Posted by Patricia Puckett on
1 Related Answer
tgmusicgirl
Lisa
  • 101 Answers
SOURCE: My 18 Bottle 2 temp wine enthusiast frig start beeping and blinking
Did you unplug for 10 seconds... then plug it back in?
Do you have any control over the front panel?
Can you verify after all of this, that the back cooling fan is working?
Their is a sensor in the back of the cabinet that monitors overheating of the thermoelectric unit... Unplugging it for a while and powering it back up is one way to verify this...
you can put a fan where the vents are in the back to speed this up...
Posted on Aug 18, 2018
Testimonial: "Thanks for your reply. I did all of that but it did not work. Yes there is digital front control panel and blinking. Also the fans are not working."
Aug 18, 2018 | Furniture
Cuisinart cwc800 wine cellar stopped chilling, fan runs well but no chilling occurs
You can get one on Amazon for $159 - service call and parts alone would be more than that.
Amazon com Cuisinart CWC 800 8 Bottle Private Reserve Wine Cellar...
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Televison & Video
Vinoview #272 02 35 18 wine cooler stopped working and makes a clicking sound
sounds like you have a compressor overheating is it enough air circulation where the unit is located and check to see that the condensing coil and motor are clean too.
Dec 11, 2013 | Wine Enthusiast VinoView Silent 35 Bottle...
I have a "the wine enthusiast" wine cooler and it's a 2001 model 2720216, 16 bottle storage, and it is not cooling the temperature stays at 80 degrees can it be fix or just get rid of it and buy a new one?
At that temp I'm sorry to say sounds like the compressor is shot or all the gas has leaked out. A service call is about $100.00 to ring the door bell and then add about $500.00-600.00 for a compressor and or 300.00 if the coil is bad. It might be better to get a new box with a warranty. Best of luck!
Aug 23, 2010 | Wine Enthusiast Grand Cru 1600 Wine Cellar...
Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Nov 02, 2009 | Refrigerators
Oster 12 bottle wine frig, how to set temp instructions please
I suggest you return that puppy as fast as you can.
The company that makes them took bankruptcy and warranties are no good.
To top it off the fans usually **** out in 6 mos or so.
May 15, 2009 | Oster 12-Bottle Wine Cellar - Black
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Furniture Logo
129 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
