Question about Samsung Audio Players & Recorders
Location of headphone jack on samsung samsung ln40b500p3fxza
Posted by Walters on
  • Samsung Master
  • 6,169 Answers
This TV does not have a headphone jack. It only has a optical digital audio output, Toslink. To connect this to most headphones, you'll need a digital to analog audio converter. You'll need to provide the cables (optical digital audio, RCA (M/M) to 3.5 mm (F) adapter). For some headphones, you can use just RCA audio cables or RCA (M/M) to 3.5 mm (M) audio cable. Here is one converter: https://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA .
The documentation for the LN40B500P3FXZA is available here: https://www.samsung.com/ca/support/model/LN40B500P3FXZA/ . See page 4 of the User Guide for the back panel connections. The current link to this guide is http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_CA&CttFileID=2430065&CDCttType=UM&ModelType=N&ModelName=LN40B500P3F&VPath=UM/201104/20110426143440007/BN68-01883Q-00L03-110426.pdf&OriginYN=N .
I wish I had better news for you. I hope this helps.
Posted on Jun 13, 2019
1 Related Answer
SD Tech
SD Tech
  • 14553 Answers
SOURCE: my samsung 40# shut off and won't come back on model# LN40B500P3FXZA please help
set has a shutdown or failsafe circuit:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Posted on Apr 01, 2012
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
How do i connect my headphone to samsung tv
Depends on your head phones and what type of connector they have. First you'll need to locate the Audio out on the TV which is usually on the back right side. Headphone Jack is located there.
see attached diagram.
Feb 02, 2014 | Samsung PN42A450 Plasma TV
I want to use the headphones for my samsung moment and I plug in the headphones and they don't work..and I looked on the settings and couldn't find anything about the headphones..please help
Is that a Samsung headphone that came with your phone? If yes, the first thing that you must do is to connect the headphone into different Samsung phone to make sure that the headphone is not defective.
As far as I believe, Samsung phones should auto detect the headphone once connected. If the phone is not detecting the headphone, then the headphone could be defective.
Try it first, then give me an update.
Thank you and good luck!
Dec 01, 2010 | Samsung Cell Phones
No volume on tv showing a set of headphones when u turn volume up or down
Your headphone jack, located on the left side of the TV, may need cleaned out. Try inserting and removing a 1/8th inch headset into the jack about 10 times to clear any dust from the connection. If this works, put a piece of tape over the jack so this does not reoccur.
Mar 14, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Connecting headphones
I looked at the manual and I can't find any evidence that you have a headphone jack which is odd. I had 17" samsung and it had a headphone jack. The only thing I can think of is Wireless headphones. You could hook them up to your audio out rca jacks on your TV. I was just looking at a pair on amazon that had the right plug ins. But I don't want to say which ones because I don't want endorse a product when I don't know how well they work. They were reasonably priced. If this helps give me a vote please.
Mar 04, 2010 | Samsung TX-R2435 TV
Headphone Jack issue Sansa View 32GB
Buy a broken one with the headphone jack intact off Ebay and switch the jacks.
Sep 08, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Headphone jack fault on 32" samsung TV
I don't know about replacing a jack but BN94-01208C fits LNT1953HX is the main pcb that has all of the av inputs on it and it is a snap to change.
Aug 03, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
No sound
See if it works with the headphone jack instead of speakers.
If the sound is intermittant on the headphone jack too then the headphone jack is broken causing the speakers not to work. You could probably find a place to solder the jack.
If it works fine on headphones then either the speakers are bad or the amplifier on the mainboard has failed.
Dec 24, 2007 | Samsung X05 Notebook
46 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
