My dish signals show 3 satallites, 110, 119, and SG, what is SG
Posted by J Lamb on
Ricoh SG 3100DN error code SC 28211, what is that and how do I repair?
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/96767-ricoh-sg-3110sfnw-showing-sc28211-error-code.html
Did not report a solution, but quoting from link above:
Ricoh Sg 3110sfnw showing SC28211 error code
Ricoh sg3110 sfnw showing sc28211 error code.
In trying to Execute carriage change sp mode (3-009-002), I cannot find 'Engine setting' (which according to the service manual) supposed to be under 'Printer setting' menu from Service mode.
Can someone help on step-by-step procedure of getting to the "Engine Setting" (sp mode) menu please in case am omitting something along the line or is their a permission required?
Dec 21, 2017 | Ricoh Office Equipment & Supplies
How do u turn on wireless capability
there should be a small button under your laptop by the mouse, click it to the right until you see the satallite dish appear or any other icon your lap has for wireless.
Mar 13, 2012 | ASUS G50V-A1 Notebook
I push fn + f8 and say: Wireless communication is disabled, how can i do for turn on the wireless communication switch?
Hi
have you tried to press FN+F8 again to enable the wireless switch
and or making sure that you have slid the wireless slide switch over to the right hand side to enable it it should show you a picture of what looks like a small satallite dish
Jul 09, 2011 | Toshiba Satellite M645-S4112 14" Notebook...
Can't get satallite channels
If you are on Satellite then it only works off of channel 3 and you will not get any other channel on the tv set. But you will need to turn your sat box remote to change channels.
Feb 27, 2009 | Televison & Video
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture quality
The output from your sat reciver is not HD unless it says right on it that it is . The signal your getting now is a digital signal from the dish to the reciver, but from the reciver to the TV set, it is analog. To answer short and sweet, Yes, you will need an HD reciver for the satallite to get the most out of your HD TV set. Good Luck Ps and please dont forget to rate this.
Oct 16, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
