Question about Acer TravelMate 3260-4874 Notebook
My orbicam is use by another application but im not using it
How to operate the orbicam because not working use another application bu t im not using it
Posted by jeaniefernan on
Anonymous
  • 53 Answers
You need to install the driver software as per the application.For each applications or operating systems, the driver software will vary.
Posted on Aug 08, 2009
Orbicam not working
There's some application whihc is using the port assigned for the webcam.Check for veriface face recognization software.
Dec 29, 2009 | Acer Aspire 5100 Notebook
Acer Orbicam Not Working
You've been spam by such spyware on your system, like worms, trojan or virus. Last night I fix like what problem you have, even I reinstall the Acer Orbicam and nothing all in connected and still use by another application. This trouble is in order to remove such malicious script or viruses. Use Spyware Doctor to remove on it. Good luck!
Jul 30, 2009 | Acer Aspire 5100-5033 Notebook
Orbicam is in use by another application
Try using an application called SplitCam, which allows you to share the webcam across applications.
http://www.pcauthorities.com/software-reviews/splitcam-share-your-webcam
May 05, 2009 | Computers & Internet
My acer orbit cam has stopped working
try to re-install the orbicam application,
if it isnot working, try to reload the operating system.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Acer orbicam
First u remove the orbicam drivers and restart.After windows booting,u insert orbicam driver cd and instal it.After installation completed,once again u restart the laptop.
Feb 25, 2008 | Acer TravelMate 3260-4874 Notebook
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
FOLLOW THE INSTRUCTIONS BELOW IN THE SAME ORDER:
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application 1.0.0.13
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
Acer orbi cam
You need 2 things, 1 is orbicam driver and 2 is orbicam application.
Checked in the device manager if your camera is installed, it shoud under "imaging device". If it is installed, you need to install the application, this software you can get from acer website (www.acerpanam.com). there are 3 type of orbicam for this model (suyin, bison, logitech), you should try one by one. the driver and application, you can download from that website (www.acerpanam.com)
The other way to solve your problem is to reload the Operating system using disks/Alt+F10, it will wipe out your c partition, it's the easiest way.
Feb 19, 2008 | Acer Aspire 5610 Notebook
Acer orbi cam not working
Checked if your orbicam is in device manager (under imaging device),
if it still there, you might have wrong orbicam application installed. try to download the orbicam application, there are 3 type of orbicam for Aspire 5050 (suyin, bison and logitech). try to installed one by one.
or if you can try to reload the whole windows, using alt+f10 during boot.
Feb 18, 2008 | Acer Aspire 5050-3242 Notebook
Acer TravelMate 3260-4874 Notebook Logo
102 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
