One moment viewing 100% hdm2 works, go back to hdml1 for a while return to hdlm 2 no sinal,checked all connections ??
  • Anonymous Jun 28, 2019
    Start getting paid every month online from home more than $15k just by doing very simple and easy job from home. Last month i have earned $17954 from this online job just by giving this 2 hrs a day using my laptop. I am now a good online earner. Get this job you guys also and start earning money online right now by follow details here............www.gocash7.com++
    Don't copy "++ " with web address
  • Anonymous Jun 29, 2019
    Making Cash more than $15k to $18k consistently just by doing basic online work. I have gotten $18376 a month ago just by working on the web. Its a simple and basic occupation to do from home and its profit are greatly improved than customary office work. Each individual can join this activity now just by pursue this link........go to this site home media tech tab for more detail support your heart :*
    HERE? ­­ www.profitclip.com
SSN-MM3
    Sergeant:
  • 272 Answers
Swapped cables? replace cables?
Posted on Jun 13, 2019
2 Related Answers
66 chrgr
mike loshbough
  • 1011 Answers
SOURCE: 1999 olds intrigue hard starting had indution
sounds like your plug wires are breaking down have them replaced along with your spark plugs!
Posted on Apr 04, 2009
bugoy31
bonifacio gomez
  • 1238 Answers
SOURCE: Changing HDMl2 back to HDMl1
using you remote..press input method press it until you reach HDMI 1..
or some remote have separate input mode buttons..
Posted on Jun 06, 2012
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
Jun 05, 2012 | Samsung Televison & Video
2001 Kawasaki KE 100 the clutch will not disengage
Hi, 6rahamf0x and the usual suspects are:
1. Clutch not properly adjusted.
2. Clutch plates rusted together.
3. Hydraulic clutch needs bleeding.
4. Faulty clutch slave cylinder.
5. Faulty clutch ramp mechanism.
6. Broken clutch rod
7. Clutch pack loose on the main shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KX100 clutch not engaging disengaging
Tricks on how to free motorcycle clutch that won disengage Live demo on...
Kawasaki KE100 service manual repair 1979 2001 KE 100 Download Manuals...$15
OEM Parts for Kawasaki
2001 Kawasaki KE100 Owner Manual
Aug 18, 2011 | kawasaki Motorcycles
T.v. flashes off and on while watching it but doesn't do it when watching dvd's
Dan,
I'm assuming that the source that flashes is sat/cab connection. If the cable types are the same between the dvd and the other source (both hdmi ?) then try swapping them. If not then purchase a cable to swap(keep the receipt and make sure you can return) to see if the problem goes away. If it is a cable/sat/dvr then try unplugging for about 30 minutes and plug back in. If that doesn't work, then try changing the input where the cable plugs into the tv . . . if its HDM1, then move it to HDM2 and make sure that you switch sources on the tv to new source . . .
The poodle guy
Nov 25, 2010 | Televison & Video
When turning on the monitor it flashes on and off and the view is distorted for a few moments after squeezing the top and bottom of the screen it returns to normal like a screw is missing.
Unplug, take the back off and re-connect all connectors and if you think it's a loose screw try tightening all screw but not over tight.Cheers!!
Oct 29, 2010 | Polaroid Televison & Video
Der is not getting sinals n my one
solution No.1
switch off your mobile n then put it on again...
solution No.2
put your moblie sim out from yours n then place the sim in some old used mobile ...make 2 or 3 calls from it...then again place the sim back to your own new mobile fone...n enjoy
Feb 12, 2010 | Nokia 3120 Cellular Phone
Computers & Internet Logo
603 people viewed this question
Ekse
Marvin
Marvin
