Question about Hayward Pool & Spa
Exchanging Hayward gas heater header assembly
Posted by Gregorio Gil on
5 Related Answers
john224
John Prohaska
  • 1378 Answers
SOURCE: when assembling header to heat exchanger is it
No...do not add anything to those gaskets.
Posted on Jan 21, 2010
Anonymous
  • 64 Answers
SOURCE: header cracked on hayward pool lo nox h250fdn
Headers on hayward heaters are usually warranted for 10 years, except for freeze or chemical damage. You may want to contact a local warranty station to see if you can get it replaced under warranty.
Posted on May 19, 2010
Anonymous
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
Anonymous
  • 15 Answers
SOURCE: My hayward h400ed2 heater starts for 2-3 seconds
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Posted on Aug 22, 2010
Kieran Ruppert
  • 990 Answers
SOURCE: hayward h250 milivolt heater cycles
Check the disc and shaft on the by-pass, then check to see if you have an external by-pass and be sure it is closed if you have one, then adjust it open a small amount.
Posted on Aug 15, 2011
How to replace the Thermostat in Hayward pool heater
go to pool store and spend the money on
Alladin or Magic Lube. It is a bit expensive and a good sized tube but its designed for your pool system. use it on all your gaskets and threads. DO NOT USE PETROLEUM BASED (vaseline)
Jun 07, 2014 | Hayward H-series Electronic Gas Pool...
Temp on water boils in heater core
This will be a water flow problem. If you have a heater by-pass it will need to be almost closed (80-90%) If the water has overheated you may need to remove the header going into the heater and replace the internal by-pass assembly.
Jul 30, 2010 | Hayward H-series Electronic Gas Pool...
I have A hayward heater H100IDEVERYTIME the heater kicks on it makes A clunking noise and the inlet hose shakes
Check your water flow and make sure your by-passes are set to send water threw the heater. That is to say shut off. The water in the heater is over heating and the clunking is the water turning to steam.
Jun 26, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have h series milvolt 350 k started heater up ...
The bypass assembly inside of the header has failed. It will need to be replaced. I would also replace the internal thermostat while you are in the header.
May 20, 2010 | Hayward H Series Pool & Spa Heater 400k...
Fixing our hotel's Hayward CSPAXI55 spa heater.
You can probally get a manuel on line if you go through Hayward.
When he took the old one out he probally just wired the circut together where the temp assembly goes into the cabnet in the top right front of cabnet in the upper panel. Then the temp probe runs around the side to the water header or manifold. If this is in the orignal spot it is on the right of the heater and easy to find. I'm not sure but if the exchanger has been turned then it will be around the back side of the header and it will be on the left side of the heater. Geting a manuel for this is a good idea anyway, good luck.
May 08, 2010 | Hayward CSPAXI11 11Killowatts Electric Spa...
Header cracked on hayward pool lo nox h250fdn heater. need to replace the header. Please help?!
May 07, 2010 | Hayward H250FDN Low NOx Natural Gas Pool...
Service SF
The temp probe is the metal disc in the header about the diameter of a quarter with three wires on it that plug into the back of the control board. Per Hayward:
Owner's manual.
Dec 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
125 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
