Question about Boating
I have tc5012 xantrex charger and have erro codes 25 and 35 ,what would be the answer
Posted by Bernard Bosma on
Jim Hicks
    Master:
  • 661 Answers
Posted on Jun 13, 2019
1 Related Answer
pctech1
Jeremy Moore
  • 1940 Answers
SOURCE: I have Xantrex prosineStatpower 3.0 24v
Error Code 207 - Internal DC Bus voltage low.
  • Temprary condition caused by low battery voltage in conjunction with an overload condition.
  • Internal fault.
  1. Check if battery is OK (see error code 002).
  2. Disconnect AC and DC power to the PROsine. Reconnect DC and AC power after 15 minutes. If the problem persists, contact Statpower Customer Service.
  3. Contact Statpower.
Error Code 002 - Battery Voltage is too low.
  • Discharged battery.
  • Old or faulty battery.
  • Battery cables to the PROsine Inverter-Charger are too small, too long, or there is a loose connection.
  1. Charge battery.
  2. Check if battery can hold the charge by measuring the Voltage at the battery terminals when the battery discharging.
  3. Check cables.
If all else fails, maybe your battery has a dead cell, or worse. Try replacing the battery, or replace the inverter/charger.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on May 18, 2011
Why does my Freedom 100 Watt Inverter/Charger remains in bulk
It sounds like a bad battery mine did the same but it was a much larger unit changed the house AGM Batteries and works perfectly
Jun 09, 2014 | Xantrex Technology Xantrex 458 10 12...
Is there a bench test for the Xantrex freedom 458 inverter/charger?
My experience has been thay there is no real "bench test" available to the general public. You can do some testing if you are familiar with how to read the color codes on resistors, and know how to test relays. There are two fuses inside, so you can check their continuity. Before going to this trouble though, get on line and download the Xantrex trouble shooting guide, bulletin No. 512-0084001-01 rev1. If that is ok, it'll be a trip to the dealer, where you'll learn that it costs about $400 to replace the board. I'm on my second one, in two years, so they aren't a long life article I'm afraid.Hope this is helpful for you.
May 09, 2011 | Xantrex Technology Xantrex 458 10 12...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
Boating Logo
136 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
