Question about Tools & Hardware - Others
Using a Hyper Tough Staple gun
Is there a safety or something you have to do before using? It has staples
Posted by Rita Hoedebeck on
5 Related Answers
Anonymous
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
Anonymous
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
joboo1
Jim London
  • 257 Answers
SOURCE: Haubold 1400 series Staple Gun has blown an ''o'' ring.
Hi, I repair lots of tools and ended up buying a complete like 2000 part o ring kit I keep in my shop, it has proven invaluable, If you can't find the o ring at a hardware store, give ample supply a call and see if they can help you, their number is 1-800-339-5667.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 27, 2009
tbirdfan1
Michael Thomas
  • 3053 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
Joe Hogan
  • 10865 Answers
SOURCE: bostitch nail gun number SB-21n1 is jammed and
Hello. Begin by disconnecting the air hose. That way you can not get hurt while removing the jam. Get a pair of needle nosed pliers and remove each of the jammed staples. They will pull out I assure you. Then Use a little WD-40 or compressor oil to lubricate the working mechanism at the firing head. IF you must loosen up the mechanism to remove all of the staple parts be sure to use the correct size allen wrench. I am providing link to a free manual for your gun in case you don't have one: http://bostitch.com/catalog_images/web_pdf/107674.pdf
Posted on Jan 12, 2010
What.size staples needed for arrow fastener ct50
It accepts two rows of T50 staples.
T50 type 17/32" Ceiltile staples
Jan 11, 2018 | Arrow Tools & Hardware - Others
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
Contact Staples to see if they can repair your shredder or replace it. It sounds like something you could get replaced with warranty.
Nov 21, 2016 | Office Equipment & Supplies
Not shooting the staples
Sounds as if you have got some staples stuck in the shoot.there is no safety lock.
Aug 17, 2012 | Tools & Hardware - Others
Tre550 stopped working
Problem is the safety micro switch. This is engaged when you press the gun against the surface. You can open the gun and short the wires. Do remember will not safety switch and hence you must ensure others know this - no children!
Apr 13, 2012 | Stanley Tools Hammer Staple/Tacker -...
I'm stumped -- I just bought a Stanley Heavy Duty TRA700. I took the "safety" off (the wire loop that holds the handle down), pinched the lever on the back and slid out the tray the staples go into. I...
The question here is what are standard staples in YOUR opinion? Are they designed to be used with this staple gun. What length are the legs of the staple 1/4" or less.
You cannot just use any staple in these guns They have to be the correct type either stanley or Bosh
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Stanley Chrome Hd Staple Gun Tr110
Is it possible to shoot yourself in the chest?
I guess it would be depending on the type of tool. Most tools have a safety mechanism that would have to be defeated or completely disabled to fire without depressing the safety and could fire freely. I would think again depending on the product that there are guidelines on the proper use and safety of the tools and as far as anyone in the house there are not kid toys and I would not let a minor use one even under supervision unless the adult knows all the functions of the tool. You can go to Stanleybostitch.com and view some of their products and manuals. I hope I answered your question
Mar 05, 2009 | Electric Staple & Nail Gun Professional...
Safety
Never let a youngster play with the staple guns. Even the manual ones eject staples with a great deal of force. If something is strong enough o enter solid wood, it is too dangerous for kids. Keep these locked up or in some safe place away from the kids. Keep the safety latch on at all times when you aren’t using it. This will prevent accidents but remember not all staple guns have this feature so you may want to look into finding one that does if you have children around. Of course, you don’t point the gun at anyone else and you keep your fingers out of the way of the staples. With a little common sense, stapling can be a fast, safe and simple way to do all kinds of repairs and projects around the house.
Aug 27, 2008 | Arrow FASTENER CO T50XP "NAIL SET...
Tools & Hardware - Others Logo
551 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
