Question about Electrical Supplies
What are the advantages of garbage disposal units?
Posted by SusanTRoberts on
Helen Daniell
    New Friend:
There are a lot of advantages to installing a garbage disposal in your kitchen. Here are just a few of them.
1. It saves time
First off, it saves time. There's nothing more annoying than having to scrape off the little bits of leftovers of every single dish one by one before you wash them. With a garbage disposal unit, you don't have to.
2. Less wastage
As your unit will break up the leftovers into tiny pieces, there is less wastage to worry about and your trash can will stay empty for longer.
3. More hygienic
By breaking up your garbage so it passes through your plumbing, little bits of food won't get stuck in your pipes. This is more hygienic and will help you to avoid nasty odors
4. Better for your plumbing
Obviously, this is the main benefits. The best garbage disposal units will ensure you have no more blockages! Click here for more information.
5. Save money
Even though you have to pay for the unit itself, you'll save money on food bags, the costs of which add up over years of use.
Posted on Jun 13, 2019
5 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
KMusselmann
KMusselmann
  • 247 Answers
SOURCE: garbage disposal leak
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Kurt
Posted on Mar 23, 2009
Anonymous
  • 63 Answers
SOURCE: I have a small leak coming from the bottom of my garbage disposal
replace unit...period
Posted on Apr 06, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
Posted on May 16, 2009
Anonymous
  • 25 Answers
SOURCE: Resetting Garbage Disposal
should have came with a alen key use it. to loosen the blades that are stuck on the bottom of the gaburator theree should be a hole in the middle. Just fine a alen key that fits in the hole and turn it around and then turn it on should solve your problem
Posted on Jun 07, 2009
Is there a reset button on the badger disposal?
If your garbage disposal won't run you may need to reset the garbage disposal using the RED overload protector button on the bottom. ... Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again. How to Reset Garbage Disposal InSinkErator
Use the wrench provided and turn disposer counterclockwise wise (of course the power is off.. do not repair it is better to replace with a new unit. Use 1/2 Hp minimum. Available at HD or Lowe's
Mar 20, 2018 | Electrical Supplies
Can my garbage disposal be fixed?
Replace disposal because parts are not available and gasket is broken?
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#install
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 18, 2014 | In-Sink-Erator InSinkErator Badger 5 1/2...
I have a badger 9 garbage disposal unit, and it leaks after installing from the discharge outlet at the top of the discharge tube under the side flange. I replaced a badger 1 and I used the old gasket as...
Location of leak is not known for sure.
Sounds like leak is where tubular drain pipe connects to side of disposal?
If leak is where disposal connects to sink, typically this connection is sealed using plumbers putty.
Open following link for disposal instructions:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
1) If leak is at rubber gasket for tailpiece connection on side of disposal:
I don't know if your local home depot sells gaskets. Probably not sold separately.
2) Go to home depot and take rubber gasket out of a new garbage disposal box.
3) Or buy new disposal with a gasket, use the gasket and return disposal saying that part was missing..
4) To seal old gasket, use rectoseal white pipe joint compound.
Cover the gasket with rectoseal and then assemble parts.
Open following link above for photo of rectoseal.
I always use rectoseal on tubular drain connections for 100% seal first time every time.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal stopped working sometimes it sounds like it wants to start for just a second but it never does. should I buy a new one?
If disposal is getting power and will not start, then motor has gone bad.
I wrote ez disposal replacement steps from when I worked apartment maintenance
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
May 27, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal makes grinding noise, as if glass or metal is in it; I've checked and checked and see nothing; what could be causing this problem?
Thanks, Geno_3245. Another thing you may be able to try is this:
(1) find your "garbage disposal wrench" - an offset Allen wrench designed to be inserted int the bottom of the disposal which was supplied with the unit (in a little plastic baggie) when the unit was brand new.
(2) with poweroff, insert the whench into the bottom of the disposal and use it to manually turn the impeller around a few times an see if anything pops loose.
If nothing comes loose, its the bearing screaming before it dies, like Geno_3245 says... so start pricing a new replacement.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishrag caught un disposal, pulled it out, blades turn, it just hums, it hums even when switch is turned on off!!
If cutter disk turns freely and motor hums, then motor winding has gone bad.
The humming sound means motor is overheating and will stop humming.
I wrote ez garbage disposal replacement steps from days when I worked apartment maintenance.
Upvote the help.
Sink only drains when garbage disposal is run. Have cleaned trap, snaked pipe and no clogs still wont drain unless disposaln is tturned on.
Sounds like a clog inside disposal.
Water should run freely through disposal.
Remove both nuts on p-trap and trap falls loose.
Put bucket under tubular drain from disposal.
Turn water on to see if water runs out of disposal.
You might need a de-greaser, drain cleaner or CLR
Check following link for tips on disposal replacement
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on plumbing or any do-it-yourself project.
Jan 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking water out of side of disposal unit
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
May 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Electrical Supplies Logo
133 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
