Question about Radio Communications
My Jace chromebook won't connect to wireless headphones. It tries and tries. The headphones are linked to bluetooth, are in my paired devices and have worked fine until just now.
Posted by Kim Moon on
John Spear
    Habit-Forming:
    New Friend:
  • 80 Answers
As a technician, I would think it’s more than likely a parent problem or it could be a battery dead on one of the devices and it cannot see it or there’s too many things generating that particular frequency in that area. Good luck
Posted on Jun 13, 2019
5 Related Answers
karlheinz
SOURCE: Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Posted on Dec 14, 2007
Anonymous
SOURCE: Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Posted on Aug 09, 2008
Anonymous
SOURCE: bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Posted on Jun 06, 2009
Anonymous
  • 10 Answers
SOURCE: how to find my passkey on my HP Integrated Module
Passkey is 0000
Posted on Sep 21, 2009
Anonymous
  • 11 Answers
SOURCE: Windows 7 and Dell BH200 Bluetooth Headphones
You have to set bluetooth as default audio device. For doing this, go to >Contro Panel> Sound and Audio Devices>Audio(Tab) and in Default Device choose bluetooth device.
In my case, I had problem when i installed SP3 on XP. I changed my bluetooth driver to "Toshiba Bluetooth Stack V6.00.10" and it worked for me.
Posted on Oct 31, 2009
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
Conecting wireless headphones LC195L9A
How Wireless Headphones Work and How to Connect Them jabra_revo_wireless_image_1440x1440px_08.jpg?h=204&w=204Wireless headphones are headphones that connect to a device, such as a smartphone, stereo speaker, television, gaming console, computer, or other electronic devices without using a wire or cable. Wireless headphones work by transmitting audio signals through either radio or IR (infrared) signals, depending on the device.
From call centers to fitness centers, wireless headphones are used by millions of people every day for work and play. For example, wireless headphones are popular with gamers, since it frees you to move around without having to worry about a cord. People doing a workout at the gym or in front of their TV in the living room love the freedom of wireless headphones. They are also perfect for people who want to watch late-night television without disturbing others.
Wireless headphones work by connecting, or pairing, with the device you want to use, through a radio or infrared signal. Many devices use Bluetooth technology to make connecting easier for the user. Devices with Bluetooth technology can connect and exchange data over very short distances using radio transmissions.
A product with Bluetooth technology has a tiny computer chip inside that contains the Bluetooth radio, and software that makes connectivity between devices possible. So when Bluetooth-enabled products, such as a cell phone and headphones, are in close proximity to each other, they connect, or pair. This enables you to talk on the phone or listen to music without wires.
Connecting a wireless headphone differs depending on the device you are using, but it's easy once you know how. Here is a list of the most popular devices that people use with wireless headphones and how to connect them.
Connect Wireless Headphones to a TV
First, make sure that your base is plugged in and the headphone batteries are fully charged. Ensure that the headphones and television are in close proximity to one another. Turn the headset on. Go into setting on your TV and turn on Bluetooth. Find the headphones under Bluetooth devices in your TV and you should be able to hear the television.
Connect Wireless Headphones to an xBox 360
The xBox 360 supports two different types of wireless headphones, ones that have Bluetooth capability and ones that do not. The first method explains wireless headphones with Bluetooth capability.
Xbox 360: Headphones with Bluetooth
  1. Plug your wireless headset into the console to install the latest headphone drivers. You will need to be connected to xBox Live in order to do this step.
  2. Make sure that your headset is charged, which can be done by simply plugging it into the unit. If you charge your headset through the console, it will connect automatically most of the time. If they don't connect automatically, turn on your console first and switch the headset so that it is in xBox mode.
  3. Press the power button for two seconds until it flashes green. You should then hear a start-up sound, and when you hear that, press the connect button for two seconds.
  4. After you release that button, press and release the connect button on the console within 20 seconds or the connection will not be made. The green lights will flash three times to let you know the connection was a success.
XBOX 360: Headphones without Bluetooth Capability
  1. Make sure that your headphones are charged, which can be done by plugging them into the USB port of the console.
  2. Turn on the console and the headphones. After they are powered up, push and release the connect button on your console.
  3. Within 20 seconds, press the connect button on your wireless headphones for two seconds. You should now hear sound from your headphones.
Connect Wireless Headphones to the iPhone
Setting up your wireless headphones with Bluetooth technology is easy on the iPhone. Here's how:
  1. Find the "Settings" icon on your iPhone, which is normally on the home screen.
  2. Open and click on the "General" button.
  3. Then, hit the "Bluetooth" button and slide it over to turn the function on.
  4. Your iPhone should find the device once this is enabled and should show the device name on screen. When it does that, you will need to hit the "Pair" button in order for the devices to sync. You may need to enter a four digit password, which is provided with your wireless device.
  5. Once that is entered, hit "Connect" on your iPhone to complete the setup. Your headphones should now be working properly.
Connect Wireless Headphones to the PS3
  1. You will first need to register the headphones to the PS3 through the Bluetooth settings. Here's how:
  2. Go to the XMB home menu and select the "Settings" icon.
  3. From there, select the "Accessory Settings" icon, and from that menu, find the option that says "Manage Bluetooth Devices."
  4. If there is no current Bluetooth device registered on the PS3, there will be an option that says "The Bluetooth device has not been registered. Do you want to register?" You will need to highlight the "Yes" option and click the "X" button on your controller. If the pairing was successful, the device will show up on the screen.
  5. Next, you will see a screen that says "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, refer to the instructions supplied with the Bluetooth device."
  6. Click on "Start Scanning" on the screen with your "X" button so that the PS3 can start to scan. Also, you need to make sure your headphones are in pair mode so that the PS3 will recognize the device. If the pairing was successful, it will show you on the screen and you just need to hit the "X" button to continue.
  7. You will then be asked to enter the pass code or security key that was provided with your wireless device. Use the keyboard that is provided on the screen to enter the pass code. Once everything is entered properly, a message tells you that the device has been registered.
  8. Next, go back to the "Accessory Settings" menu to access the "Audio Device Settings" menu. Select the "Input Device" option by clicking "X" on the controller. When the new menu opens, look for the proper microphone input that corresponds with your device. Once you find the right one, click the "X" button.
  9. Select the "Output Device" option to select the headphones. Once you search through the options that the system recognizes, click "X" on your wireless headphones to select them. You should now be set up and ready to use the wireless headphones and microphone.
Connect Wireless Headphones to an iPod
  1. jabra_revo_wireless_image_1440x1440px_14.jpg?h=444&w=444Make sure that your wireless headphones have Bluetooth capability.
  2. Access the "Settings" icon on the home screen of your iPod. Select the "General" option once you are in that screen.
  3. You will then see an option that says "Bluetooth", which you can slide over to enable Bluetooth on the iPod.
  4. Be sure that your wireless device is in discovery mode so that the iPod can recognize it.
  5. Once you enable the Bluetooth on the iPod, it will list any devices that is recognizes. Simply click on your wireless device when the iPod shows it and click the "Connect" button. Your headphones should now be paired and working properly.
HOPE THAT HELP - GOOD LUCK.
Feb 01, 2015 | Sylvania LC195SL9 19 in. LCD TV
How can I get my player to connest to my bluetooth headphones have tried several times no luck
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).
Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on.
Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES.
You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.
HTH
Jul 31, 2014 | iLive IHB603B Micro Bluetooth Stereo...
How do wireless headphones work
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
Feb 15, 2014 | Sony Audio Players & Recorders
Why wont kinivo bth220 wont link with my phone no matter what i try
Can you confirm if you are able to put the BTH220 headphones in pairing mode. Please try the following steps and see if works:
  1. Make sure that the headphones are fully charged.
  2. Switch off the headphones.
  3. Put the headphones in pairing mode by pressing the MFB button (center) for 7-10 secs till you see the red and blue LED blinking alternatively. Please do not leave the button as soon as blue LED appears.
  4. Follow the operating instruction of your Bluetooth device to start the pairing process.
Sep 29, 2012 | Kinivo Bth220 Bluetooth Stereo Headphone -...
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
How do i connect my backbeat 903 to my phone
Pairing Your Headphones and Phone/Device
1 Turn on your phone’s or device’s Bluetooth® feature.
2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat.
See your phone’s or device’s user guide for more information.
4 If prompted, enter 0000 for the PIN code/passkey.
Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
(from plantronics web site)
Apr 04, 2010 | Altec Lansing BackBeat Plus Mobile ...
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Mar 11, 2009 | Jabra BT3030 Wireless Headset
Cant play music
What software are you using to pair the headphones?  Are you using the software from the CD that came with the headset?  Or are you using Windows built-in software?
If you are using Windows' software, then you need to download the correct driver from the link below.  Although the Windows software will pair with any bluetooth device, it does not support audio.
http://drivers.anycom.com/bluetooth/usb-200-250/anycom-bluetooth-usb200-250-windows-v5-1-0-4200.exe
If you are using the CD that came with the headset, try uninstalling then re-installing.
Feb 06, 2009 | Insignia Bluetooth Wireless Headphones...
Radio Communications Logo
150 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
