Question about Plantronics Radio Communications
Plantronics C054 disconnects after 30 seconds.
Posted by Michelle Awtrey on
1 Related Answer
Anonymous
SOURCE: connection lost between Plantronics 510 Voyager and blackberry
I ave exactley the same problem on my Samsung sgh g600
Posted on Oct 07, 2008
Need help with charging. my plantronics c054 does not hold a charge
If it will not hold a charge then the battery pack is worn out/defective and you must replace it. You can find the number on the battery and get them on eBay.
Jun 08, 2017 | Plantronics Radio Communications
How to set up the plantronics C054 hesdset. I do not hear a dail tone
Call 1-855-765-7878 for Plantronics support. There are a few things that it could be. The support is free
Jan 02, 2015 | Plantronics CS 540 - Headset convertible ...
Mistake sorry everyone, plantronics voyager pro x cs70 .cannot get to work on my nokia c2-01 please help
Oftentimes there may be interference from other bluetooth devices on the phone. Disable them first, disconnect the battery from the phone for 30 seconds (helps to reset) and follow the pairing instructions from the link below.
Plantronics Voyager Pro User's Guide
Good luck from Headsets Direct!
Sep 30, 2011 | Plantronics CS70 Wireless Headset
I have new bluettooth plantronics220 but I try pairing it doesn't go trough. please help me
First you want to make sure that your phone is free of any other bluetooth interference. Disconnecting the battery of your phone for 30 seconds and reconnecting it helps to reset the phone. Then carefully follow the instructions on pages 4 & 5 from this link:
Plantronics Explorer 220 User's Guide
Sep 22, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I can't get my Plantronics 390 Explorer headset to pair with my new LG Octane phone!
You want to make sure there are no other bluetooth devices installed on your phone that might be interfering with the pairing process. Disconnect the battery from your phone for about 30 seconds and reconnect (to reset the phone). Then follow the pairing instructions found on pages 3-5 of this link for the Plantronics Explorer 390 User's Guide.
Sep 11, 2011 | Plantronics Explorer 390 Bluetooth Headset
Problems with dicovery 925 keep blinking purple light and can't pair with the phone help
Something you may want to try is start from the beginning. Check to make sure there are no other bluetooth devices loaded onto your phone that might interfere with the process. Turn off your phone. Disconnecting the battery of your mobile for 30 seconds and reconnecting helps to reset the phone. The instructions for turning off the headset and re-pairing the two devices are located in the following link for the Plantronics Discovery 925 User's Guide.
Sep 03, 2011 | Plantronics Discovery 925 Bluetooth...
When I make a call using the bluetooth, I can hear who I am talking to through the bluetooth, but they can't hear me?????
Make sure both devices are fully charged. Turn off your phone and disconnect the battery for about 30 seconds (this helps to reset the phone). Make sure there are no other bluetooth devices interfering with the connection. Turn off your headset and carefully follow the pairing instructions on the link below for the Plantronics Discovery 925.
May 12, 2011 | Plantronics Discovery 925 Bluetooth...
My voyager pro will auto pair with my samsung gt-b2710 but then disconnects after 5 seconds
I would suggest deleting the Voyager Pro from your phone. Turn your phone and headset off and then back on after about 30 sec. You will need to reconnect the headset to the phone again. Use pass code 0000 (4 zero's) if you phone ask for it. See page 8 of user guide for further tips. User guide attached below.
Dec 11, 2010 | Plantronics Voyager PRO Bluetooth Headset
Radio Communications Logo
169 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
Ekse
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
