SOURCE: Colibri lighter
Usualy there are screw at the bottom.
If there are no screws at all. that means the lighter is assembled in 'click-on' way and you have to use your imaginary engineering skills.
Start with a part which looks attached to lighter the last.
Posted on Dec 21, 2008
SOURCE: need to replace battery in
Thank you for contacting FixYa. Place the tip of your pocket knife in the slot on the back of the watch. Pry the back off. Take your tweezers and grasp the metal piece that is hiding the battery. Once that metal piece is out the battery should come out too. Put the new battery in and cover it with the metal piece. Put the back of the watch back on and snap it into place.
Best wishes. Jewel
Posted on Oct 05, 2010
SOURCE: battery required for colibri lasertron
This lighter would normally use a CR1240E-T lithium 3 volt battery. If you still have an old flat battery, it can be charged if you know what you are doing. OK, so you don't have an old battery, so there are 2 types of battery that you can use to sort the problem. A lot of advice out there suggests using a CR1225, with a little packing to make up for the lack of thickness, this I have found barely works, as the capacity is so low to start with. And now for the real solution........ I use two silver oxide 391 batteries (11.6mm X 2.1mm @ 1.55volt each). With bits of paper to insulate the positive poles from shorting, and more paper to insulate the screw down cover from touching the top battery. The whole thing takes only a couple of mins, and you'll have months worth of bright red light and powerful sparks. Good luck John P. [email protected]
Posted on Jan 01, 2012
SOURCE: what battery to put in colibri sensatron lighter
303 or 357. when you take old battery out it may be diffrent number need to convert number / use retna battery chart
Posted on Feb 02, 2012
