Question about Garden
I just bought a black and decker string trimmer 20V MAX. The string will not feed automatically and keeps breaking so that only about 2 inches is left.
Posted by Betty Perkins on
john h
    Top Expert:
  • Garden Master
  • 23,424 Answers
Read owners manual on how to string unit
Posted on Jun 18, 2019
5 Related Answers
Anonymous
  • 313 Answers
SOURCE: black and decker grasshog trimmer line feed problem
email [email protected] or see www.dewaltservicenet.com look for the find it now icon & enter the model #
Posted on Jul 28, 2008
Anonymous
SOURCE: does not automatically feed out line
I am a bit upset. I purchase a Black and Decker Trimmer and you guys want to charge me almost 10$ to give me a little bit of advise on a problem. Than I find in that email that if I have fixed the problem you want me to email you and tell you how I did it. FOR FREE. Well I did fix it. If you would like to know how mail me 10$. Only fair. [email protected]
Posted on Jan 29, 2009
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: only 1 string trimmer /// string keeps feeding when running
You have the string wound the wrong way on the spool.
Jim
Posted on Jun 17, 2009
glen mullens
  • 133 Answers
SOURCE: string won't advance automatically. Thank you so
There is a rachet mechanism at the bottom of the spool. make sure the spool is seated fully. Also make sure the string isn't wound too tight or it will stick and not advance.
Posted on Apr 20, 2010
glen mullens
  • 133 Answers
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Posted on Apr 21, 2010
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Line doesn,t feed automaticly
The line may be on backwards or has developed a knot. Debris may have worked its way inside the bump head preventing it from functioning.
Check out these items.
Best regards
Mike
Aug 20, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
String won't advance automatically. Thank you so much for any assistance! It's a Black & Decker ST 7000 edger/trimmer.
Apr 06, 2010 | Black & Decker St7000 13'' Automatic Feed...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I have a Black and Decker Grass Hog trimmer and I can't get it
There is only a couple of reasons that I can think of that would cause this
1. The string is wound the wrong direction; it should be wound clockwise on the spool. (This is my bet.)
2. Or maybe, the string is too small for your particular trimmer, but this is very doubtful.
Jim
Jun 18, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Only 1 string trimmer /// string keeps feeding when running
Jim
Jun 17, 2009 | Black & Decker 14" Grass Hog Xp...
Does not automatically feed out line
Jan 28, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
