Question about RCA Televison & Video
I can change the input on my RCA tv. But it will not stay where I move it to. How can I make it stay at the new location?
Posted by Sherry Douglas on
2 Related Answers
Anonymous
SOURCE: Lost TV remote while on alternate INPUT
Another expert site answered my question. Since there was no INPUT button on the TV, I need to buy an original remote.
Posted on Jul 19, 2009
jerry_kramer
Jerry Kramer
  • 3904 Answers
SOURCE: I cant change the input on my rca tv it stays on dvd mode stating there is no disc How do i get it off dvd mode the input button is not working
You can use the input menu button on the TV as well as the remote to change the input.
Posted on Apr 18, 2016
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
We had our ps2 hooked up to an old rca tv and was using the satelite remote for it channel had to be on 00 for the ps2 to work. We got a new tv and hav moved the rca and ps2 to another place but don't...
New tv's don't use dead channels like 00 anymore for there inputs.. They use sources to change from different inputs.. Make sure you have your ps2 hooked up into input plugs on the tv and then turn it on the ps2 then look on the new controller for the tv & find a button saying source .. Press that until you see your ps2 on the screen. If not check your connections try again.
Feb 03, 2012 | RCA Televison & Video
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
Jul 18, 2009 | Directed 434MHZ Remote Control
Tv won't stay on
it is a brandnew tv, so expected that it is under warranty,, it best for you to return where you bought so the warraty will not void. Big possible of factory deffect.
Dec 26, 2007 | RCA 20F420T 20" TV
Cable connector repair
use RCA cables instead of ch 3
Oct 24, 2007 | RCA D52W15 TV
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Televison & Video Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
