SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
SOURCE: Dryer drum will not turn
sounds like a power promblem to me check at out let for 220 volts if you have it there first turn circete breaker off then on try drier if that dont get it check for power at outlet with meter if 220 is there after unplugging drier check cord at back of drier at terminal block if all thats ok then you have a bad door switch a bad start switch or a bad thermal limiter last and rare bad drive motor
check to see if there is a little red button on the back if so push it in thats your re-set button
SOURCE: Avanti portable dryer - drum does not rotate
The belt is broken . Call Avanti to get it fixed or take it back and get it replaced .
SOURCE: Kazuma Panda 110 Quad - Starting problem
have you tried a new spark plug???? try new sparkplug there may be a spark on the old one but it may not be strong enought, if that dont work you know its petrol problem!
