Question about Bosch Dishwashers
I have a bosch dishwasher. The dispenser open and the detergent comes out (Finish tablet)but it gets stuck at the front of the top rack (actually middle rack, I have a 3-row) and nothing gets clean.
5 Related Answers
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
yuckydishes
SOURCE: Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Posted on Mar 31, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
wiringlunati
Charles Reifinger
  • 576 Answers
SOURCE: whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Posted on Nov 25, 2009
dnkypunch
  • 37 Answers
SOURCE: Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Posted on Jan 22, 2010
Detergent tablet will not dissolve?
Check water temp in might be to cool that is the first step......
Oct 06, 2014 | CDA WC430 Dishwasher
ADP 4730
The problem is with either the spring or the solenoid that operates the detergent compartment door. It should be released at the right time by the controller during wash cycle. You have to check the spring and see if it stuck. But if solenoid is faulty then whole detergent dispenser has to be replaced. You could switch to detergent tablet which you drop in the cutlery basket and it works fine. A brand like Finish works well and keeps dishwasher clean.
Alternatively you can purchase a replace detergent dispenser from
http://www.buyspares.co.uk/whirlpool/adp4730-851150429849/dispenser/product.pl?pid=18330&path=463858:496324,47872:463870&refine=dispenser&model_ref=641830
Also watch the video on how to replace.
Apr 23, 2014 | Whirlpool Dishwashers
Detergent dispenser doesn't open
There is a solenoid in the detergent dispenser that opens at the appropriate time to let the door open and drop detergent. The solenoid might be faulty if the door spring appears alright. One option is to stop using the powder detergent and switch to tablets. One tablet like Finish diamond in the cutlery basket does wonders.
Not sure if you can buy the dispenser to replace.
Apr 22, 2014 | Indesit Dishwashers
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Mar 05, 2011 | Whirlpool DU840CWD Dishwasher
Soap tablet not dispensing happens every 2nd or
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Jan 05, 2011 | Bosch 24 in. SGS43E08 Exxcel Built-in...
Not dispensing detergent properly---not getting top rack clean-------could this be a problem with the kitchen drain? I clean the filters often. I have Model SHU43C Thanks for the help, Barbara...
Hello Barbra. Not likely a drain problem because the machine is evacuating of the water from the sump. The bottom rack i assume is ok.
So the top rack in not doing it's job.
1.......clean out all of the timy holes in the spray arm.
2.......make sure there is nothing stppind the top arm from turning
give it a flick to see if it spins around freely
3..... tall object in the bottom can stop the arm from turning.
4.......some bosch machines have a divertor valve to alternate the water from the top to bottom racks. The valve. if faulty can be stuck in the bottom position not allowing the top arm to turn. Yopu can check this by turnint both arms to line up with easch other, say both arm ends pointing to you . then close the door and start the machine. after a short while of hearing the water swishing, open the door and see if the arms ahve moved. if both arms are turning then you know the divertor valve is ok. Even if your model does not ahve a divertor valve this is a good way of testing the spray arm operation.
Always use good quality soap and avoid tablets. use powder and make sure you have rinse aid in the dispenser.
Aug 06, 2010 | Bosch Dishwashers
White film on inside of dishwasher on racks and dishes, plasticq
There will adjustment in the respective compartments for reducing or increasing the detergents. Adjust this. Refer manual. Finally have a look at the inlet water quality for excessive calcium!
Apr 15, 2010 | Bosch SHU5315UC Dishwasher
BOSCH DISHWASHER SHU33A DETERGENT DISPENSER WON'T POP OPEN
try some liquid detergent, somehow these powder and tablets tend to stick in and keep the door shut...
Sep 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Detergent Dispenser does not open
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwashers Logo
136 people viewed this question
Top Bosch Dishwashers Experts
peter gittos
peter gittos
Marvin
Marvin
Ekse
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
