Vacuums Logo
Question about Dyson Vacuums
Dyson v6 absolute flashes the red light 32 times then turns off why is that and how do I fix it thanks
Posted by Paul David Johnson on
dvd4me
32 blinks it's a lock status that cannot be reversed by placing the battery in the charger. It's triggered by the unbalance voltage between the cells. The battery design does not implement balancing so they are sort of destined to fail by the 32 red light blinks.
If the cells are still good, there is a method to reset the lock status. One needs to open the pack, balance the cells manually and then re-start the pack.
More details on this forum: https://www.eevblog.com/forum/reviews/dyson-v7-trigger-cordless-vacuum-teardown-of-battery-pack/50/
Hope it helps
Posted on Feb 24, 2022
Rob Huston
  • 21 Answers
Dyson's site reports: "A flashing red light indicates that there is a fault, please call the Dyson Helpline."
Posted on Sep 19, 2019
4 Related Answers
askdyson
AskDyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: how do I fix dyson cordless vaccum flashing red light
    Hi there, it's Jack at Dyson.
    A flashing red light from a Dyson cordless vacuum signals a fault with the machine. We're happy to take you through some simple diagnostic checks over the phone when you have your machine easily to hand - just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    If a replacement part is needed we can also confirm if this is covered under your Dyson guarantee.
    We'll look forward to speaking with you.
    Posted on Feb 20, 2015
    emissionwiz
    Marvin
    • 85242 Answers
    SOURCE: The red light on my Dyson V6 cordless keeps blinking I try to charge it won't turn on it won't do anything what do I need to do to fix it
    Replace the battery pack.
    Posted on Nov 26, 2017
    jmacisaac61890
    tim patterson
    • 32 Answers
    SOURCE: battery got hot on dyson v6 before it died i plugged it in but just get a flashing red light, it flashes 32 times when trigger is pressed, does this mean battery is broken?
    yes burnt out
    Posted on Mar 31, 2018
    Mai Lor
    • 2558 Answers
    SOURCE: My dyson absolute blue light is flashing it has been charging for 30 mins and will not start
    -Why chose Dyson...? Lot of peoples complaint about it.
    Good luck
    Mai
    Posted on Jun 12, 2018
    2answers
    V6 Red light blinks 32 times
    Your Dyson may not have been connected to the charger correctly when last put away.
    2answers
    I have a Dyson v6 animal handheld and It will not turn in. The indicator light flashes blue one time and then flashes red one time. I’ve searched and searched for a solution but can not seem to find any...
    First check it is fully charged. Secondly, Try checking all the pipes, tubes and attachments for blockages. Basically take it to bits and clean it. Dyson have a 'cut out' feature fitted to stop you burning out the motor when it's blocked up.
    Hi Dyson v6 animal won't charge when it is put in cradle red light continues to flash
    Dyson's site reports: "A flashing red light indicates that there is a fault, please call the Dyson Helpline. "
    My Dyson v8 Absolute has both blue lights on and only holds charge for approx 1 min or so.
    Whilst the battery should flash Red if the battery is faulty, 50% of the time it doesn’t. I can 99% Guarantee you that you need to replace the battery.
    2answers
    I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
    not trying to be a smart a** but which of the two do you have?
    1. A flashing blue light indicates that the battery is running low on charge.
    2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
    FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
    Best to you.
    My Dyson V6 absolute is pulsating when I pull the trigger. I have cleaned the canister and checked for obstructions. I also cleaned the top filter.
    Hello, this is Ava with Think Crucial.
    There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the unit. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
    You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    https://www.thinkcrucial.com/search?type=product&q=dyson+v6
    I hope this was helpful.
    Ava B.
    Think Crucial Customer Care
    http://www.thinkcrucial.com/
    My Dyson v6 animal is pulsating but has been cleaned and been on charge All night
    There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
    Ava B.
    Dyson v6: It looks like it stopped charging.
    If it's only 2 weeks old, you could have a defective either charging system or just a bad battery. Most places offer free replacement within 30 days of purchase. I would take it back to your place of original purchase. I hope that helps!
    2helpful
    2answers
    I can't the the max mode to turn off. How do I fix this?
    Hi Kayla, it's Jack at Dyson.
    To switch between Max mode and regular mode, first hold down the red on/off trigger, so the vacuum is running. Then at the same time, press and release the Max button on the rear of the machine. The machine is designed in this way to make Max button can't be activated accidentally. When running in Max mode, the button will light up.
    I hope this information helps, If you'd like any additional advice, you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    David Shaub
    Mike
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
