Question about Xerox Office Equipment & Supplies
Xerox machine erroer code 004-350 - Xerox Office Equipment & Supplies
Posted by yogesh patil on
  • Jean DeLauche
    Jean DeLauche Jun 11, 2019
    Hello Yogesh - What is the model of your Xerox machine? I assume you do not have the user manual for it. Can you please add details in the comment box? Best wishes.
docukaaf
    Habit-Forming:
  • 38 Answers
Hy the problem is because some chip is wrong, may be chinese change it one for one until solve the problem
Posted on Jun 16, 2019
  • docukaaf Jun 16, 2019
SSN-MM3
    Sergeant:
  • 272 Answers
XD103F Xerox work centre flashes error 7 help needed
First a fault code on your Xerox printer and or multifunction device is not always as disastrous as you might imagine, no reason to slink away from the machine. The fault code is just a way for your machine to tell you there is a problem and it needs some help. So next write down the complete code and any accompanying error message, the fault code will be numbers and/or letters and may include commas, periods or hyphens. Then find a device on which you can access the internet. At the computer or smart device go to Xerox.com and then select the Support & Drivers tab at the top. Enter the model of your Xerox printer or multifunction device in the field provided and then select the machine and select Support. On the machine support page you will see the "Search For Keyword or Phrase:" field. You can enter the fault code there or right under that field you can click on the "Fault Code Search" link. A new screen will be displayed where you can enter the fault code or you can scroll through all the codes looking for the one you wrote down from your machine
Oct 10, 2018 | Xerox Office Equipment & Supplies
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
Feb 19, 2018 | Xerox Office Equipment & Supplies
I've lost my enablement code for my Xerox WorkCentre 5655. Can you tell me the enablement doce please sir?
Contact Your Xerox Sales Representative
If the enablement code is not known, whether this is a new machine or not, contact your Xerox Sales Representative to obtain the code. Only the Xerox Sales Representative will have access to the enablement codes.
Unfortunately, there is no way to obtain an enablement code outside of calling your Xerox sales rep for the following features:Scan to File (Network Scanning), Scan to Email, Server Fax, Network Accounting, Embedded Fax, Internet Fax, or Overwrite Security
I hope this helps///
Unfortunately
Mar 05, 2015 | Xerox Office Equipment & Supplies
Panasonic dp 8035 e04-01
How can remove E04-01 macheen erroer from panasanic DP 8035 photostate machin
Dec 23, 2013 | Office Equipment & Supplies
Fault code problem whit xerox 5665
This sounds like a fuser problem, underheat or over heat. On this machine also, it might be related to NVM, or NVM memory corruption. Sometimes the batteries on the Main Board, they just get old and die.
This can be a multiple problem on the machine.
This might require a Xerox service person to visit the machine.
Some ideas are: A bad heat sensor(Thermistor), very fragil and brittle.
A NVM might need to be reset, Over heat or underheat code in the diagnostice service mode. You need a service manual to find it.Very complicated to explain.
A full sump bottle can cause this, the machine enters a code in the NVM and will keep the machine from "Logicly turning on." Or a broken full sump bottle, sensor falls off or not in place will cause the machine to enter a error code in the NVM.
Good luck.
Apr 03, 2009 | Xerox 5665 Copier
Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Jan 05, 2008 | Office Equipment & Supplies
47 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
