Question about LG Refrigerators
How do I set the LG freezer temperature? I tapped "Freezer" and it went to -0 degrees! Model LMXC23796D/00
Posted by Faye Johnson on
Philip Morand
    Sergeant:
  • 205 Answers
Hold freezer button in to lower temp - should be -5 to -8 degrees in freezer side. https://www.6ya.com/callphilipforhelp
Posted on Jun 12, 2019
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
Anonymous
  • 75 Answers
SOURCE: Freezer not staying cold
thermistor has worned out so please change the thernistor then you ll find the temperature gets maintained in 0 degrees......
Posted on Sep 10, 2008
Anonymous
  • 750 Answers
SOURCE: Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless of control setting. Fridge maintains 40 degrees at mid setting. Shouldn't the freezer be close to zero? Is there a way to check the temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
Posted on Oct 03, 2008
Michael Anderson
  • 172 Answers
SOURCE: Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 28, 2008
Anonymous
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Whst temperature do I set LG LFX 31945ST
Hey Rosalie,
The lower the temperature the better but do not operate to the extreme.
  • I would set the freezer between 0 and 7 degree F
  • The fridge between 34 & 37 degree F
  • Adjust Temp if necessary.
Here is a link to the fridge manual.
Good Luck!
JP
LG LFX31945ST Owner Manual
Jul 19, 2015 | LG Refrigerators
What temperature should freezer be set
Set at 0. That is the Fahrenheit setting equivalent to 32 degrees Celcius; the temperature at which matter freezes.
Sep 30, 2013 | LG LFC22740 Bottom Freezer French Door...
Electricity off want to reset temperature. What should frig and freezer be set?
Temperatures are preset at the factory at 38 degrees or 3 C in the refrigerator compartment and 0 degrees F or -18 C in the freezer compartment. Here is a link=> MFI2067AES User Manual to the user manual for your model that explains how to set the temperature, I am here should you have questions Thanks Sea Breeze
May 29, 2013 | Maytag MFI2067AES Stainless Steel Bottom...
I am trying to return the freezer and refrugerator settings to 37 and 0 , how do I do that?
There is a dial or button pad inside the fridge that controls the temperature up or down.
some displays are not so clear so just adjust your fridge slowly either way until you get to the desired temperature
37 degree Fahrenheit = 2.78 degree Celsius
0 degree Celsius = 32 degree Fahrenheit
Oct 28, 2010 | LG Refrigerators
I am having LG GR-B352 YC , what is the best temperature that i can keep initially and future??
Generic instructions to set temperatures in fridges:
Many manufacturers design these appliances to operate at 0 degrees F in the freezer and 34 to 36 degrees F in the fresh food compartment.
To set the temperature correctly, fill a glass with water (8 to 12 ounces) and place a thermometer capable of indicating 32 degrees and up into the glass with water (if the temperature goes below 32 degrees, the water will freeze - so no need to find a thermometer that indicates any lower). Place the glass with the thermometer in it on a shelf and wait. Putting the thermometer in a glass of water helps preserve the temperature reading while the door is open. You can skip the water and glass if you want - but you'll need to read the temperature as soon as you open the door.
The freezer will require a thermometer capable of displaying 0 degrees F. Place it on a shelf where it can be seen readily - but preferably in the rear - between items (to prevent the warm air from driving the indicator up when opening the door to read it).
It will probably be easier to set the freezer temperature first. Adjust both the freezer and fresh food thermostats to mid-points (if the fridge is empty - otherwise skip this step). Adjust the freezer thermostat up or down as needed to reach the desired 0 degree F temperature.
Once the freezer adjustments are complete, adjust the fresh food compartment thermostat as needed up or down to reach the desired temperature for it.
If you fridge is fully stocked, it may take some time for the temperature to stabilize and warm / cool the fridge's contents completely. This is further affected by how often the door(s) are opened and for how long. 24 hours is often claimed - but you might be able to sneak an 8 - 12 hour soak before reading the thermometers.
After the temperatures are set, you may find that the lower part of the fresh food area is partially freezing - simply adjust the thermometer up *slightly* as needed.
Please rate this reply if it was helpful - good luck!
Aug 11, 2010 | Refrigerators
Sep 10, 2008 | GE PTS25LHP Top Freezer Refrigerator
Refrigerators Logo
93 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
