Dishwashers Logo
Question about Fisher and Paykel Dishwashers
How to Remove service panel on Fisher and Paykel Nautilus dishwasher to replace door springs. Where is section 6.1 (not linked in instructions)
Posted by Margaret Johnson on
5 Related Answers
Anonymous
  • 5911 Answers
SOURCE: dishwasher f1 problem on fisher paykel
All the information that I have found about this particular problem indicates that the "F1" error is a flood or overflow alarm. It's generally caused by a clog in the drain line and/or tub not sealing properly when closed.
If this is a drawer style dishwasher there is a lid in the equipment cabinet that must seat properly on the drawer when it is closed. If you place items in the dishwasher that are too tall for the drawer lid to seat properly, it will not seal and water will splash over the sides of the tub during the wash cycle.
Another common problem is a clogged or kinked drain line. Remove the drain hose and make sure it is not plugged. Check it at BOTH ends.
The alarm is activated by a float switch in the bottom tray of the dishwasher. Look to see if this is any standing water in the bottom tray. If there is any water, or signs of wetness, the alarm will not clear until it is dried out. I found a couple of recommendations to clear the alarm. The first involved removing the dishwasher from where it is installed and tilting it at a 45 degree angle to pour any standing water out. Another method is to dry the bottom out with towels as best you can, and then use a hair dryer to dry any residual water. I hope I'm on the right track with this and I hope this solves your problem. Post back if you have any further questions.
CAUTION: UNPLUG the dishwasher or turn off the breaker BEFORE servicing inside the cabinet.
Posted on Feb 20, 2008
Anonymous
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
Anonymous
  • 145 Answers
SOURCE: Fisher & Paykel Nautilus Dishwasher
F4 is a fault code telling the controller that the water is not heating up. This can be caused by either a faulty heater plate, a bad connection between the plate and controller, or the controller itself. If you wish to fix this yourself, changing the heater plate is a fairly involved repair and should be done by someone with a high degree of mechanical ability.
Posted on Dec 11, 2008
Anonymous
  • 212 Answers
SOURCE: the panel cover on my fisher & paykel nautilus is broken
Fisher and paykel is based out of australia. call the # in the manual to order part. they have a division in california. parts usually take me two to three weeks to recieve.
Posted on Jun 21, 2009
Anonymous
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
Fisher and Paykel Nautilus Dishwasher 01 error approx. 15 mins after starting
01 is a door switch fault. it is possible that the switch is corroded and the moisture is causing it to fail, making the machine think the door is open, and it will stop and tell you this.
if you can open the door, and inspect the switch, see if it clicks when pushed.
Fisher and Paykel Nautilus Dishwasher wont advance to take water in .
The problem could be with flood switch at base of dishwasher. Press the float to check if it springs back. Otherwise switch under it is faulty.
Fisher & paykel dishwasher- Nautilus manual
Please check page 19 of the manual. Not sure if this is what you are asking. You can take both the spray arms out.
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
1helpful
2answers
Fisher and paykel nautilus dw920 Need instructions to replace door latch (with images if possible) part # 521809
Hi - here are the instructions to help with your project
1. Isolate from power.
2. To remove the outer door panel, remove the eight screws securing it to the inner door panel. Be careful of sharp edges.
3. To remove the handle, remove the six torx drive screws securing it through the inner door panel.
4. Refit in reverse manner.
Note: 230 volts is still present at the detergent dispenser and electronic P.C.B. unless power is isolated at the plug outlet or mains.
Location: The door handle latch is located within the centre of the handle moulding
and is retained by a pivot latch. The microswitch is situated on the side of
the latch and is clipped in.
1. Remove outer door and handle (refer Section 6.2).
2. Remove the latch by sliding it away from the P.C.B. console.
3. Unclip the microswitch from the latch.
4. Ensure the springs and microswitch lever are fitted to the latch when re-assembling.
Sorry I cannot provide a sketch for public view, I may get into trouble.
Cheers
2helpful
Door drops down no tension
what do you mean buy the door has no tension. looking at the model number it is the two drawer glide systm
1helpful
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
1helpful
1helpful
The panel cover on my fisher & paykel nautilus is broken
Jun 21, 2009 • Dishwashers
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Marvin
Marvin
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
