Question about Samsung Cameras
My samsung st30 camera wont switch on - Samsung Cameras
Posted by jeandixon402 on
  • Anonymous Jun 10, 2019
    Have you tried sweet-talking it ?
  • jeandixon402 Jun 11, 2019
    dont know what you mean?
Tony Parsons
  • Samsung Master
  • 6,301 Answers
Check batteries and battery compartment for corrosion.
Posted on Jun 10, 2019
Testimonial: "thankyou, yes already done that, no corrosion"
Why does my panasonic st30 tv menu not work
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
The fault should be of bad remote control, if the switches at the front panel of the TV works properly. If it too do not work at all, the fault will be of its main system control memory IC. Contact any service technician, if this is the case.
Aug 02, 2014 | Panasonic "Viera Tcp65 St30 65"" Class...
Not power off
I guess you can't switch the camera off when you are using it. But when you don't switch it off, the battery runs out.
After you charged the battery, what happened. Or next time, when it won't switch off, remove the battery, Then watch what happens after you reinstall the battery and try to switch it on.
If you can switch on the camera the switch is ok. If the camera starts immediately, after you inserted the battery, the switch is blocked. (makes full contact without you touching it). This is a real problem, and I think only can be repaired in the service centre. Please ask before what it will cost, because sometimes it is cheaper to buy a new camera.
Oct 31, 2013 | Samsung ST30 Digital Camera Pink
Samsung camera problems
when trying to power off the camera a green light which is on the right corner blinked and the images are displayed continuously. What could be the problem?
Apr 25, 2013 | Samsung ST30 Digital Camera Pink
Hi, I bought a Samsung ST30 a couple of weeks ago, and have only been using it one evening so far. A couple of days ago I was about to use it again, but I noticed that it had runned out of charge, so I...
Hi.
The camera is obviously faulty and needs to be returned to the manufacturer or the store for replacement or repair. The warranty will cover any cost so will be done free of charge.
You have every right to be angry as it is brand new.
Regards.
Aug 13, 2011 | Cameras
I try to install the CD drive for my new Samsung ST30 it took me 3 hours but still it was not successfull so I cannot transfer my pics from the camera to the computer using the usb cable
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jul 30, 2011 | Computers & Internet
Samsung S1065 digital camera. Won't witch on. Len won't extend, beeps three times, switches off. Any ideas gratefully accepted.
my samsung camera s1065 the lens wont extend when switching on the lens does not extend ,it bleeps 3 times but then closes down
Aug 28, 2010 | Gateway DC-M40 Digital Camera
My samsung l200 camera wont connect with my computer, what's wrong?
Blame windows updates. Solve your problem by using a card reader from now on.
Jul 12, 2010 | Samsung L200 Digital Camera
Samsung PL50 camera wont unlock memory card
There is a little sliding switch on the side of the memory card. Make sure it is not on lock.
Mar 01, 2010 | Cell Phones
Cameras Logo
654 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
