Question about Pioneer Car Audio & Video
Radio is on but no sound even when cd is in and volume is turned 20 there is no sound. Speakers is conected prope. What can be wrong that no sound is coming from radio/cd
Pioneer deh 1430r
Posted by Yvonnevan Reenen on
Yudesh govind
    New Friend:
  • 3 Answers
Speaker ices are damaged
Posted on Jun 10, 2019
  • Yudesh govind Jun 10, 2019
5 Related Answers
Anonymous
  • 91 Answers
SOURCE: PIONEER DEH 245
Most aftermarket radios follow the same color code. W G G P, White, Grey, Green, Purple. LF, RF, LR, RR. red is switched ignition, yellow is constant battery, black ground.
Posted on Sep 02, 2008
Anonymous
I need a manual for PIONEER DEH 245.
Posted on Oct 04, 2008
Anonymous
SOURCE: No sound with iPod Adapter CD-IB100II in the DEH-P2900MP
on the radio and the adapter their is a spot for the cord that connects the two the ends have different colors on them it should be purple and black just make sure the colors are matched up if they are off it will still read all the info and say its playing but no sound will come out
Posted on Nov 12, 2008
Anonymous
  • 8 Answers
SOURCE: radio shows on but no sound to speakers
I flooded my Eclipse and the AMP is under the passenger seat. Might have got wet and ruined it. They are expensive from the dealership ($900). Try a junk yard.
Posted on Nov 17, 2008
mikehumble
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
Why are my speakers of my Monsoon radio making noise when ignition key is off?
Depending on the year of the car. The factory amp may be wearing out and need to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/nathaniel_9ed79ef078a2f164
Aug 05, 2014 | Pontiac G6 Cars & Trucks
Put the radio in my truck about 4 months ago, worked great. the truck sat for months because it was broke, now i get it fixed, put the face on my radio and everything is on, my radio, my amp is running but...
Turn the volume up to the highest level.
Can you hear a hiss or static?
NO...usually means speakers are disconnected..often loose socket at rear of radio or broken wiring
YES...Hiss means either blown speaker, faulty radio or faulty aerial.
If you have tape or CD as well , this will prove whether it is the aerial or not.
HISS with CD or tape playing means faulty radio or speakers
WORKING OK with CD or tape means faulty aerial
Feb 20, 2011 | Car Audio & Video
I have a 2001 mitsubishi eclipse spyder. i am having problems with my radio. my radio will turn on change channels and except a cd but nothing comes out of my speakers. I cheacked all speakers no loose...
A couple of things could be wrong.
your valume control could be bad causing no sound to go to speakers.
The circuit board in the radio the controls the volume is damaged.
Oct 18, 2017 | 2001 Mitsubishi Eclipse Spyder
Power cuts out for approx. 3 seconds when volume is turned up above 20, the must be turned down or will cut out again.
it looks like you have a speaker going bad disconect all four speakers and conect one by one
Sep 30, 2009 | Kenwood KDC-MP232 CD Player
I have a 1999 Chevrolet Suburban with the factory radio. The radio works fine but when I put in a cd and turn the volume up some, it just stops playing for about 20 sec. It will come back on at a very low...
sounds like your popping the breaker, after a while your speakers will go, theres just too much power for it to handle, take it to a car audio store and get them to test it, you may need new speakers
Jun 20, 2009 | Car Audio & Video
Aux in runs only back speakers and no volume control
check sub setting some radios can select between non fading sub output or aux input
May 08, 2009 | Pioneer DEH-P3000 CD Player
The radio turns on....it isn't locked but sound is still not coming in through the speakers. it displays a radio station and accepts cd's,but no sound. HELP!!
pull out the radio, make sure the conections are good, If the vehicle isn't equipped with an amplifier( i don't think they put amps in any silverados) then replace the radio.
Feb 26, 2009 | 2003 Chevrolet Silverado 1500
Durabrand DB1215 car radio
I have a db 1210 and i need the wireing plug for the speakers can you help
Jun 04, 2008 | Durabrand DB1200 CD Player
Volume won"t pass 20 cut's off dack
the speakers either cannot handle the poew and shut off to protect the radio- or the wiring for the speakers are not insulated well or your groung is not good
Mar 26, 2008 | Alpine CDA-9833 CD Player
Speakers dropping out & engine sounds
sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Sep 03, 2007 | Pioneer DEH-P690UB CD Player
Car Audio & Video Logo
136 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
