Question about Lands Phones
SOURCE: It won't charge the rechargeable batteries anymore
I have the same problem , the only logical reason i could think of is that the charger connecting to the base station has malfunctioned .
Posted on Oct 07, 2008
SOURCE: bad rechargable battery?
You may try MCM Electronics at 1-800-543-4330. They will need all the info from the battery.
Mike
Posted on Mar 16, 2009
SOURCE: needs recharging
AA (4) batteries (NiMH recommended). Walmart sells a recharger for AA batteries. Buy the NiMH type as they last WAY longer than your typical alkalines. If you don't use the camrea for a while top off the charge. If you keep spares charged and they sit for about a month - top them off too.
Posted on Apr 24, 2009
SOURCE: I need to get a replacement battery for my Simens Gigaset A120
I usually recommend batteryspecialists.com but I couldn't find this battery there. Here is a link for a very reasonably priced battery for your Gigaset A120:
Posted on May 13, 2009
SOURCE: New battery 6600 mAh does not charge anymore
It is possible it is a bad battery again. Also could be a bad solder joint on the DC jack or bad AC adapter. To test power off and unplug the laptop, remove the battery. Now plug in the AC and power on the PC. If it comes on, gently wiggle the AC plug going into the PC. If it shuts off you have a bad DC jack solder joint. If it stays on the battery is probably bad or the battery connector on the PC. If the PC doesn't come on at all with just the AC gently wiggle the AC plug and tap the power button repeatedly. If it comes on briefly than off again it is the jack solder joint. If it doesn't come on at all then it's a safe bet the AC adapter is bad.
Posted on Apr 18, 2012
Mar 18, 2014 | Siemens GIGASET-A510IP VoIP Phone w/...
May 19, 2012 | Lands Phones
Dec 02, 2010 | Siemens Gigaset A140 Cordless Phone
Jun 11, 2010 | Siemens Gigaset 4200 Cordless Expansion...
Apr 16, 2010 | SkyGolf SkyCaddie Handheld GPS Unit
May 17, 2009 | Siemens Gigaset 4010 Cordless Phone
Aug 30, 2008 | Philips VOIP8411B/37 IP Phone
May 23, 2008 | Siemens Gigaset 4000 Phone
173 people viewed this question
