Question about Watches
Need instructions to program Accutime watch WM-1-BSIN. It will change only hour. Not minutes or date.
Minutes will only change back and forth between 30minutes.
Posted by Christina Aaron on
Terry
  • Watches Master
  • 11,124 Answers
Contact Accutime by phone or web:
http://www.accutimewatch.com/contact-us.html
Posted on Jun 15, 2019
Tom Chichester
    Top Expert:
  • Watches Master
  • 55,379 Answers
Google (accutime)(WM-1-BSIN)(manual) without parens for instructions.
Posted on Jun 10, 2019
1 Related Answer
ANDY PLUMB
  • 150 Answers
SOURCE: Gear keeps changing back and forth while driving at constant spee
Check the transmission fluid level and top up
Posted on Mar 14, 2009
Change 12 to 24 hr & date
Hi bobwesley,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Timex 1440 Nylon watch
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
Hope it helps.
Nov 13, 2010 | Timex 1440 Nylon watch
I cant set the right date on my timex 1440 sports watch
Hi travislietha,
To set the right date on your timex, please follow the instructions below.
Hope it helps.
Jun 28, 2010 | Timex 1440 Nylon watch
I would need to set the time on my timex WR50M watch and I have missed place my instruction sheet. I would need th instructions Thank You
Hi fuscoromeo,
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
Hope it helps.
Nov 02, 2009 | Timex 1440 Nylon watch
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
Hope it helps.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
Military time on timex 1440
Hi bud76502,
Hope it helps.
Oct 02, 2009 | Timex 1440 Nylon watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
Armitron Watches
From the time telling mode press the set button the seconds will flash.
Press the mode button the hours will flash
Press the adjust button to change the hours
Press the mode button the minutes will flash
Press the adjust button to change the minutes
Press the mode button the month will flash
Press the adjust button to change the month
Press the mode button the date flashes
Press the adjust button to change the date
Press the mode button the day flashes
Press the adjust button to change the day
Press the set button when done.
Mar 11, 2008 | Watches
Watches Logo
275 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
